Acus One for Strings 6T Simon Acoustic Guitar Amplifier (wood) Acus One for Strings 6T Simon Acoustic Guitar Amplifier (wood) Acus The Acus One for Strings 6T SIMON is a 130 W acoustic guitar amplifier, equipped with 3 inputs (2 Mic-Line and 1 Line) with Gain / Volume controls, 3-band equalizer, and Effect send. Arts & Entertainment > Hobbies & Creative Arts > Musical Instrument & Orchestra Accessories > Musical Instrument Amplifiers Acus-One-for-Strings-6T-Simon-acoustic-amplifier-wood 03000503 1049.00 DjangoBooks.com
Home / Amplification / Amplifiers / ACUS Amplifiers / Acus One for Strings 6T Simon Acoustic Guitar Amplifier (wood)
Acus Sound Engineering developed the One for Strings range to amplify the sound level of all acoustic instruments (notably acoustic and classical guitars) without altering their natural tone or resonance. One for Strings amps are designed in minimalist style, with custom speakers, cabinets and highly reliable electronic components, all together capable of amplifying harmonics with natural tone.
Perfect for gigging, practice or recording, the Acus One for Strings 6T SIMON is a 130 W acoustic guitar amplifier, equipped with 3 inputs (2 Mic-Line and 1 Line) with Gain / Volume controls, 3-band equalizer, and Effect send. Thanks to the Stereo Input with RCA connections to the Stereo Output it is possible to connect respectively an external audio source and send the signal to an external recorder. In addition, the One for Strings 6T SIMON has a balanced Direct Output, Phantom Switch and Master Volume.
The Simon version is a limited edition version of the Acus One for Strings 6T amplifier, distinguished from the standard model by the housing made from specially selected wood with tilt function and black chrome front grill.
$1,049.00
Specs
Frequency Response - 50Hz - 20kHz
Max Power Out - 130 W
System format - Biamp 2 vie
Woofer Power - 90 W
Tweeter / Horn Power - 40 W
Sensitivity 1W 1m - 92dB
SPL MAX - 114d
Crossover - Electronic
Woofer size - 6"
High Freq driver - Compression tweeter
Box - 2 Vie bass reflex
Construction - Birch Plywood
Weight - 24lbs
Height - 34.5cm
Width - 28.5cm
Depth - 29cm
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013225 Seconds Memory Usage: 1.360428 Megabytes
