Acus One for Strings Cremona Acoustic Amplifier (wood) Acus One for Strings Cremona Acoustic Amplifier (wood) Acus The Acus One for Strings Cremona is an amplifier designed specifically for for classical instruments like violin, viola, and classical guitar. Arts & Entertainment > Hobbies & Creative Arts > Musical Instrument & Orchestra Accessories > Musical Instrument Amplifiers Acus-One-for-Strings-Cremona-acoustic-amplifier-wood 05000100 1699.00 DjangoBooks.com
Home / Amplification / Amplifiers / ACUS Amplifiers / Acus One for Strings Cremona Acoustic Amplifier (wood)
Acus Sound Engineering developed the One for Strings range to amplify the sound level of all acoustic instruments. One for Strings amps are designed in minimalist style, with custom speakers, cabinets and highly reliable electronic components, all together capable of amplifying harmonics with natural tone.
The Acus One for Strings Cremona is an amplifier designed specifically for for classical instruments like violin, viola, and classical guitar. It is equipped with a TSF System, a custom audio preamplifier designed by R&D department of Acus in Recanati. The TSF system, thanks to a perfect balance of even/odd harmonics, can create natural sounds and accurately reproduce all the harmonics of high-quality acoustic instruments.
The amplifier has a exclusive high fidelity audio preamplifier (based on the TSF system), 3 inputs (Mic-line) complete with Peak Led, 4-band equalizer, filter HFS, Effect Send and Volume, Aux input with dedicated Volume, Direct Out (with -10dB and PRE / POST) and manual "feedback canceled" filter. Other features a headphone output with dedicated volume control and 4 high quality effects with Eff Return control.
05000100 - Acus One for Strings Cremona Acoustic Amplifier (wood)
$1,699.00 | Out Of Stock | Stock Notification
Specs
Frequency Response - 40Hz-20KHz
Max Power Out - 200 W
System format - 2-way Biamp
Woofer Power - 150 W
Tweeter - 50 W
Sensitivity 1W 1m - 94 dB
SPL MAX - 116 dB
Crossover - Electronic
Woofer size - 8"
Tweeter - Compression tweeter
Box - 2-Way Bass Reflex
Construction - Birch Plywood
Weight - 28.6lbs
Height - 38.4cm
Width - 28.7cm
Depth - 32cm
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013291 Seconds Memory Usage: 1.358162 Megabytes
