Acus One for Strings Extension Cabinet (wood) Acus One for Strings Extension Cabinet (wood) Acus The Acus One for String Extension cabinet is an extension sound box designed as a small PA system, particularly suitable to the sound of acoustic instruments. Arts & Entertainment > Hobbies & Creative Arts > Musical Instrument & Orchestra Accessories > Musical Instrument Amplifiers Acus-One-for-Strings-Extension-wood 03000805 899.00 DjangoBooks.com
Home / Amplification / Amplifiers / ACUS Amplifiers / Acus One for Strings Extension Cabinet (wood)
The Acus One for String Extension cabinet is an extension sound box designed as a small PA system, particularly suitable to the sound of acoustic instruments. This cabinet has been especially designed to work in conjunction with the Acus One for Strings 8 200W Amp, boosting volume levels while maintaining the rich, natural tone and resonance of the instrument. The One for Strings Extension includes an 8" woofer speaker, along with compression tweeter with an electronic crossover, powered by a 150 Watt power section.
The One for Strings extension cabinet is housed in a compact, portable plywood shell and offers a lightweight construction that can be easily transported between gigs or rehearsals.
$899.00
Specs
Frequency responce: 40 Hz – 20 kHz
Max power out: 200 W
Syistem format: 2-way Biamp
Woofer power: 150 W
Tweeter: 50 W
Sensitivity 1W 1mt: 94 dB
Spl max: 116 dB
Crossover: Electronic
Woofer size: 8"
Tweeter: Compression tweeter
Cabinet: 2-way bass reflex
Construction: Birch Plywood
Weight: 28.6 lbs
Height: 38.4 cm
Width: 27.7 cm
Depth: 32 cm
Acus One for Strings 8 Acoustic Guitar Amplifier (black)
One for Strings 8 is the second largest in their line of acoustic amplifiers, featuring a 200W acoustic guitar amplifier and an 8" Woofer and compression tweeter.
$1,299.00
Acus One for Strings 8 Acoustic Guitar Amplifier (wood)
$1,299.00
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013502 Seconds Memory Usage: 1.411163 Megabytes
