Audio-Technica AT831B Lavaliere Condenser Microphone Audio-Technica AT831B Lavaliere Condenser Microphone Audio-Technica Audio-Technica AT831B Lavaliere Condenser Microphone Electronics > Audio > Audio Components > Microphones audio-technica-AT831b AT831b 5.0 1
5 5
It's a good quality mic.I didn't test it outside on a live gig just in my studio.Connected to a studio preamp this mic will give you clean,nice,full body sound with a lot of natural transients using guitar soundhole adapter or placing mic inside guitar.I didn't buy optional gooseneck adapter but with little adaptation I use small clip which you get in the box.This mic is also great in combination with other studio mic as Neuman.Recordings with this two mic's are really superb.And I'm not talking...
229.00 DjangoBooks.com
Home / Amplification / Pickups / Audio-Technica AT831B Lavaliere Condenser Microphone
This is the higher performance version of the PRO 70. It has a wider frequency response then the PRO 70 which captures the high end frequencies more accurately. This very mic was used by Stochelo Rosenberg and Romane on the Gypsy Guitar Masters CD and DVD. Amazing sound!
Audio Technica AT831B Lavalier Microphone
For years this condenser microphone has been one of the top choices in the industry for lavalier microphones and can be found installed in many of the top wireless lavalier systems as well.  It also can serve as an acoustic guitar mic mounted in the sound hole. The cardioid pickup pattern ensures the best possible pickup directly in front of the microphone while minimizing external noise, thus resulting in minimal feedback.  The microphone comes with a tie/collar clip and terminates to a power module with battery.  In place of the battery, the microphone can also be powered by 48 volt phantom power.
Features:
  • Clip-on lavalier mic also excels in acoustic guitar applications
  • Provides crisp, full-sounding voice and instrument pickup
  • Operates on battery or phantom power
  • 6' (1.8 m) cable permanently attached between microphone and power module
Specifications:
  • Element: Condenser
  • Polar Pattern: Cardioid
  • Frequency Response: 40 - 20,000 Hz
  • Open Circuit Sensitivity: PHANTOM: -44 dB (6.3 mV) re 1V at 1 Pa; BATTERY: -45 dB (5.6 mV) re 1V at 1 Pa
  • Impedance: PHANTOM: 200 ohms; BATTERY: 270 ohms
  • Maximum Input Sound Level: PHANTOM: 135 dB SPL, 1 kHz at 1% T.H.D.; BATTERY: 121 dB SPL, 1 kHz at 1% T.H.D.
  • Signal to Noise Rati 65 dB, 1 kHz at 1 Pa
  • Dynamic Range (Typical): PHANTOM: 106 dB, 1 kHz at Max. SPL; BATTERY: 92 dB, 1 kHz at Max. SPL
  • Phantom Power Requirements: 9 - 52V, 2 mA typical
  • Battery Type: 1.5V AA/UM3
  • Battery Current/Life: 0.4 mA/1200 hours typical
  • Switch: Off/on-flat/on-roll-off
  • Low Frequency Roll-off: 80 Hz, 18 dB per octave
  • Weight: 0.1 oz (2.8 g)
  • Power Module: Inline
  • Output Connector: XLRM-type (power module)
  • Accessories: AT8116 foam windscreen; AT8417 clothing clip; AT8444 instrument adapter; AT8530 power module (attached); battery; protective case
$265.00 $229.00 (Save 14%)
Good mic
It's a good quality mic.I didn't test it outside on a live gig just in my studio.Connected to a studio preamp this mic will give you clean,nice,full body sound with a lot of natural transients using guitar soundhole adapter or placing mic inside guitar.I didn't buy optional gooseneck adapter but with little adaptation I use small clip which you get in the box.This mic is also great in combination with other studio mic as Neuman.Recordings with this two mic's are really superb.And I'm not talking about Selmer style guitars only but for all acoustic guitars,classical nylons and even archtops in combination pick-up + AT831B (great jazz sound) Regarding live performance I hope it will be great too as I tested on my studio monitors with pretty high volume before any usual feedback.
Submitted by: Dalibor on 01/10/2012 04:24:35 AM
Audio-Technica AT8418 Unimount Microphone Instrument Mount
$49.99
Audio-Technica AT8468 Guitar or Violin Mount
The Audio-Technica AT8468 is a hook-and-loop fabric, touch-fastener mount for mounting lavalier microphones to violin and guitars.
$21.00
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.025466 Seconds Memory Usage: 1.987457 Megabytes
