Home / Amplification / Pickups / Audio Technica Microphones / Audio-Technica AT8418 Unimount Microphone Instrument Mount
The unimount is a great way to avoid getting proximity effect/bass bomminess from having a lavalier too close to the soundhole. You can use this to mount a microphone behind the bridge or even in the soundhole! When used in the sound hole feedback is greatly reduced.
  • Works Specifically for the PRO7O & AT831B lavalier microphones
  • Rubber-Grip Spring Clamp Holds Mic Securely to Instrument Without Marring the Finish
  • Flexible Boom Permits Aiming the Microphone in Any Direction
  • Cable Strain Relief Reduces Cable-Transmitted Noise and Cable Damage
  • Item Number:
    6905
    $49.99
    Audio-Technica AT831B Lavaliere Condenser Microphone
    $265.00 $249.00 (Save 6%)
    Audio-Technica PRO 70 Cardioid Condenser Lavaliere / Instrument Microphone
    $199.00 $159.00 (Save 20%)
    Much better!
    Pros: Any position and multiple mount options.
    Cons: Little pricy for a gooseneck but still worth it.
    Big improvement over what's in the box when you buy the PRO70. The original clip works of course, but this one allows you to position the mic (inside or out) in pretty much any position. I've switched from inside the sound hole to inside the body to gain more volume/tone, and I've brought it outside of the guitar for some outdoor gigs to get a more realistic sound. Works every time, easy to adjust and doesn't damage your finish at all. I highly recommend this for those using a PRO70.
    Submitted by kohno on 04/23/2011 07:52:45 AM.
    Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.015646 / 1.516075]
