Audio Technica Cardioid Condenser Instrument Microphone with Surface Mounting System (5" Gooseneck) ATM350S Audio Technica Cardioid Condenser Instrument Microphone with Surface Mounting System (5" Gooseneck) ATM350S Audio-Technica Cardioid Condenser Instrument Microphone with Surface Mounting System (5" Gooseneck) ATM350S Electronics > Audio > Audio Components > Microphones audio-technica-atm350s ATM350S 299.00 DjangoBooks.com
Home / Amplification / Pickups / Audio Technica Cardioid Condenser Instrument Microphone with Surface Mounting System (5" Gooseneck) ATM350S
Designed for use with accordions and other instruments that are difficult to mike, the ATM350S UniMount® mounting system gives you the tools to perform with confidence. The system features the ATM350a cardioid condenser microphone, a high-SPL mic that provides a clear, well-balanced response from any instrument.
When teamed with the included AT8491S surface mount and strong, flexible AT8490 5" gooseneck, the mic can be securely fastened to an accordion or other instrument with a challenging mounting surface and be positioned where you want it – the mic will stay in place no matter how much you move the instrument as you play. The microphone's cardioid polar pattern isolates the instrument by reducing side and rear pickup, and the switchable 80 Hz high-pass filter on the in-line power module helps control undesired low-frequency noise. The system also includes an AT8468 violin mount with hook-and-loop fastener and a protective carrying case.
$299.00
Specs
Element     Fixed-charge back plate, permanently polarized condenser
Polar Pattern     Cardioid
Frequency Response     40 – 20,000 Hz
Low Frequency Roll Off     80 Hz, 12 dB/octave
Open Circuit Sensitivity     –49 dB (3.5 mV) re 1V at 1 Pa
Maximum Input Sound Level     159 dB SPL, 1 kHz at 1% T.H.D.
Dynamic Range     130 dB, 1 kHz at Max SPL
Signal-to-Noise Ratio     65 dB, 1 kHz at 1 Pa
Phantom Power Requirements     11– 52V DC, 3.5 mA typical
Switches     Flat, roll-off
Weight (Microphone)     14.5 g (0.5 oz)
Weight (Power Module)     90 g (3.2 oz)
Cable     4.0 m (13.1') long (permanently attached to microphone), 3.2 mm (0.13") diameter, 2-conductor shielded cable with HIROSE HR10-type connector
Dimensions (Power Module)     92 mm (3.62") long, 18.9 mm (0.74") diameter
Dimensions (Microphone)     37.8 mm (1.49'') long, 12.2 mm (0.48'') maximum body diameter
Output Connector (Power Module)     Integral 3-pin XLRM-type
Optional Interchangeable Elements     UE-H hypercardioid (100°) UE-O omnidirectional (360°)
Accessories Included     ATM350a cardioid condenser microphone; AT8543 power module; AT8491S UniMount® surface mount; AT8475 surface mounting kit; AT8490 UniMount® 5" gooseneck; AT8468 violin mount (hook-and-loop fastener); protective carrying case
Audio-Technica Case Style     M36
Audio-Technica AT8418 Unimount Microphone Instrument Mount
$49.99
Audio-Technica AT8468 Guitar or Violin Mount
The Audio-Technica AT8468 is a hook-and-loop fabric, touch-fastener mount for mounting lavalier microphones to violin and guitars.
$21.00
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.023123 Seconds Memory Usage: 1.953629 Megabytes
