Audio-Technica ATM350U Cardioid Condenser Instrument Microphone Audio-Technica ATM350U Cardioid Condenser Instrument Microphone Audio-Technica Audio-Technica Audio-Technica ATM350U Cardioid Condenser Instrument Microphone with Universal Clip-on Mounting System (5" Gooseneck) Electronics > Audio > Audio Components > Microphones audio-technica-atm350u ATM350U 299.00 DjangoBooks.com
Home / Amplification / Pickups / Audio-Technica ATM350U Cardioid Condenser Instrument Microphone
The microphone�s cardioid polar pattern isolates the instrument by reducing side and rear pickup, and the switchable 80 Hz high-pass filter on the in-line power module helps control undesired low-frequency noise. The system also includes an AT8468 violin mount with a hook-and-loop fastener and a protective carrying case.
Designed for use with brass, saxophone and other instruments, the ATM350U UniMount mounting system gives you the tools to perform with confidence. The system features the ATM350a cardioid condenser microphone, a high-SPL mic that provides a clear, well-balanced response from any instrument. When teamed with the included AT8491U universal clip-on mount and strong, flexible AT8490 5 in. gooseneck, the mic can be clipped securely to the bell of your instrument and positioned to stay where you want it � the gooseneck won�t flop around no matter how aggressively you move the instrument as you play.
Features
  • Low-profile mic design for minimum visibility
  • Crisp, clear, well-balanced microphone response, even at high SPLs
  • UniMount universal clip-on mount attaches securely to instrument bell
  • Rugged UniMount 5 in. gooseneck rigidly holds its shape
  • In-line power module is equipped with a switchable 80 Hz high-pass filter to control undesired ambient noise
$299.00
Specs
Audio
  • Analog or digital: Analog
  • Frequency response: 40Hz � 20kHz
  • Max SPL: 130dB
  • Connectivity: XLR
Pattern and Type
  • Capsule: Dynamic
  • Polar pattern: Cardioid
  • Type: Mounted
  • Switches: Not specified
  • Phantom power required: No
Size and Weight
  • Diameter: .48 in.
  • Length: 1.49 in.
  • Weight: 3.2 oz.
Included Accessories
  • Case: Yes
  • Clip: Yes
  • Shockmount: No
  • Power supply: Not applicalbe
  • Cable: No
  • Stand: No
Audio-Technica AT8418 Unimount Microphone Instrument Mount
$49.99
Audio-Technica AT8468 Guitar or Violin Mount
The Audio-Technica AT8468 is a hook-and-loop fabric, touch-fastener mount for mounting lavalier microphones to violin and guitars.
$21.00
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.016807 Seconds Memory Usage: 1.957825 Megabytes
