Audio-Technica ATM350UL Cardioid Condenser Instrument Microphone Audio-Technica ATM350UL Cardioid Condenser Instrument Microphone Audio-Technica Audio-Technica Audio-Tech nica ATM350UL Cardioid Condenser Instrument Microphone with Universal Clip-on Mounting System (9" Gooseneck) Electronics > Audio > Audio Components > Microphones audio-technica-atm350ul ATM350UL 309.00 DjangoBooks.com
Home / Amplification / Pickups / Audio-Technica ATM350UL Cardioid Condenser Instrument Microphone
The microphone�s cardioid polar pattern isolates the instrument by reducing side and rear pickup, and the switchable 80 Hz high-pass filter on the in-line power module helps control undesired low-frequency noise. The system also includes an AT8468 violin mount with a hook-and-loop fastener and a protective carrying case.
Designed for use with brass, saxophone and other instruments, the ATM350UL UniMount� mounting system gives you the tools to perform with confidence. The system features the ATM350a cardioid condenser microphone, a high-SPL mic that provides a clear, well-balanced response from any instrument. When teamed with the included AT8491U universal clip-on mount and strong, flexible AT8490L 9" gooseneck, the mic can be clipped securely to the bell of your instrument and positioned to stay where you want it � the gooseneck won�t flop around no matter how aggressively you move the instrument as you play.
Features
  • Low-profile mic design for minimum visibility
  • Crisp, clear, well-balanced microphone response, even at high SPLs
  • Cardioid polar pattern reduces pickup of sounds from the sides and rear
  • UniMount universal clip-on mount attaches securely to instrument bell
  • Rugged UniMount 9 in. gooseneck rigidly holds its shape
$309.00
Specs
Audio
  • Analog or digital: Analog
  • Frequency response: 40Hz � 20kHz
  • Max SPL: 130dB
  • Connectivity: XLR
Pattern and Type
  • Capsule: Dynamic
  • Polar pattern: Cardioid
  • Type: Mounted
  • Switches: Not specified
  • Phantom power required: No
Size and Weight
  • Diameter: .48 in.
  • Length: 1.49 in.
  • Weight: 3.2 oz.
Included Accessories
  • Case: Yes
  • Clip: Yes
  • Shockmount: No
  • Power supply: Not applicalbe
  • Cable: No
  • Stand: No
Audio-Technica AT8418 Unimount Microphone Instrument Mount
$49.99
Audio-Technica AT8468 Guitar or Violin Mount
The Audio-Technica AT8468 is a hook-and-loop fabric, touch-fastener mount for mounting lavalier microphones to violin and guitars.
$21.00
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.012975 Seconds Memory Usage: 1.411919 Megabytes
