Benedetto B6 Standard Mount Humbucker (6 String) Benedetto B6 Standard Mount Humbucker (6 String) Benedetto Benedetto B6 Standard Mount Humbucker (6 String) Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories > Guitar Accessories > Electric Guitar Pickups benedetto-pickup-b6 B6 5.0 1
5 5
I wanted to significantly alter the sound of my Gretsch Electromatic 5120 by replacing the stock Gretschbucker pickups. Both neck and bridge pickups were replaced with Benedetto B-6, about a two hour job. Although I haven't had a lot of time to play, my first impressions are that these are ideal jazz pickups: they produce a warm, rich, deep, mellow sound, with a very smooth and even response across all strings. The Ebonova finish is also very elegant. My only issue is that I may need to replace ...
129.00 DjangoBooks.com
Home / Amplification / Pickups / Benedetto B6 Standard Mount Humbucker (6 String)
B-Series ­ This is basically a “built-in” version of the S-Series. It maintains the same natural acoustic qualities of the instrument. According to Bob Benedetto, this pickup is “the best sounding jazz pickup I’ve ever heard. There isn’t even a close second.”
Description: Standard mount, humbucking, 6 string guitar pickup.
B-6 (6-string)
Magnet ­ Alnico V Bar
Cable ­ 4-Conductor shielded. Allows multiple wiring options.
DC resistance ­ 12.10 K Ohms
Inductance ­ 7.10 H
Resonant Frequency ­
            Series  -  4.29 KHz
            Split  -  7.93 KHz
Body Measurements ­ 2.74 x 1.49 x .70"
Centers of Mounting Legs - 3.062"
$185.00 $129.00 (Save 30%)
Ideal jazz pickups
I wanted to significantly alter the sound of my Gretsch Electromatic 5120 by replacing the stock Gretschbucker pickups. Both neck and bridge pickups were replaced with Benedetto B-6, about a two hour job. Although I haven't had a lot of time to play, my first impressions are that these are ideal jazz pickups: they produce a warm, rich, deep, mellow sound, with a very smooth and even response across all strings. The Ebonova finish is also very elegant. My only issue is that I may need to replace the humbucker mounting rings taken from the original pickups with taller ones, at least in the bridge position. But otherwise the pickups are just what I wanted.
Submitted by: Rolf on 08/21/2012 02:09:06 PM
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.020451 Seconds Memory Usage: 2.279388 Megabytes
