Fishman Pro-EQ Platinum Bass Preamp Fishman Pro-EQ Platinum Bass Preamp Fishman Designed to plug in between your axe and amp, the Fishman Pro-EQ Bass Preamp provides feedback control, photo-optic compression, 5 bands of EQ, and XLR direct out with ground lift, and tuner/send output. Arts & Entertainment fishman-pro-eq-bass PRO-PLT-BAS 159.95 DjangoBooks.com
Home / Fishman Pro-EQ Platinum Bass Preamp
Breathe new life into your electric or standup bass!
Designed to plug in between your axe and amp, the Fishman Pro-EQ Bass Preamp provides feedback control, photo-optic compression, 5 bands of EQ, and XLR direct out with ground lift, and tuner/send output. 3 midrange bands plus bass and treble are optimized for the electric or upright bass and easily dial out runaway frequencies. The bass slider's range is 30-275Hz which lets you precisely tweak G-string tone. Feedback can also be controlled with Depth and Phase switches. Ergonomically shaped with rubber feet to keep the unit from wandering. Operates on 9V battery or optional AC adapter.
Features
Outputs: Main, XLR main, Tuner/Send
5-band EQ
Depth control
Compressor
6600 - Fishman Pro-EQ Platinum Bass Preamp
$253.76 $159.95 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.016828 Seconds Memory Usage: 1.183495 Megabytes
