Fishman TriplePlay Wireless Guitar Controller Fishman TriplePlay Wireless Guitar Controller Fishman TriplePlay is the composing, performing and recording system that puts an unlimited palette of instruments and sounds at your fingertips – all with the freedom of wireless control. Arts & Entertainment fishman-triple-play-wireless-guitar-controller PRO-TRP-301 339.95 DjangoBooks.com
Home / Fishman Pickups and Preamps / Fishman TriplePlay Wireless Guitar Controller
Turns your guitar into a wireless MIDI synth and more.
TriplePlay is the composing, performing and recording system that puts an unlimited palette of instruments and sounds at your fingertips – all with the freedom of wireless control. Compose music with unparalleled tonal options. Easily share arrangements with your band. Switch between instruments, or play up to four instruments at the same time. Teach or learn faster with accurate notation. Create video soundtracks. Mix your own samples, beats, loops and tracks.
Easy to use
The controller's durable, low profile design fits neatly behind your guitar's bridge, and it's wireless, so no heavy 13-pin cables to trip over. The rechargeable Lithium Ion battery has over 20 hours of life – plenty of juice for a full day of composing and a night of gigging. Accessible onboard menu navigation buttons, volume control, and the guitar/mix/synth switch make it easy to change settings or instruments during performances.
Easy setup, easy removal
TriplePlay can be installed or removed quickly, on virtually any electric guitar, with no permanent installation necessary. Mounting hardward included.
Complete Software Suite Included
TriplePlay comes complete with all the software you'll need for recording, editing and playing back your music. Take full advantage of powerful MIDI features with your guitar. With the easy and blazingly fast note encoding, preset editor and mixing console, you'll be mixing your own music in no time. Includes full versions of:
Native Instruments – Kontakt Elements and GuitarRig LE
Notion Music – PROGRESSION
IK Multimedia – SampleTank 2 XT and AmpliTube Custom Shop
PreSonus – Studio One Artist TriplePlay Edition
Features
Two input channels with 3-band EQ
Includes Wireless Controller, Hexaphonic Pickup, and Wireless USB Receiver, mounting brackets and hardware, fast charge power pack, and USB charging cable
Wireless technology eliminates proprietary bulky cables
Works with industry standard DAWs and Virtual Instruments
Unique "hold" feature and string or fret splits with multiple instruments
Simple to install on your electric guitar and can be easily removed
Low profile design (less than .5") can be left on your guitar and still fit in its case
Over 100 foot range
Operates with rechargeable Lithium Ion battery (included)
Menu navigation controls
Guitar, Mix, Synth switch easily accessible while performing
Guitar synthesizer volume control
USB powered wireless receiver interfaces to computer or iOS device
6600 - Fishman TriplePlay Wireless Guitar Controller
$615.31 $339.95 | Out Of Stock | Stock Notification
Amp Specs
TriplePlay Wireless Guitar Controller Specifications:
Material: Durable composite and metal finish
RF Range: 100 feet*
Controller Dimensions: 3.25" H (82.5mm) x 2.93" W (74.4mm) x 0.51" D (12.9mm)
Power: Rechargeable Lithium Ion battery
Battery Life: Over 20 hours
Pickup Dimensions: 4.11" L (104.4mm) x 0.34" W (8.6mm)
Pickup Height Adjustable Range: .35" min. (8.9mm) to .58" (14.7mm) max. from tallest point between G & D strings
* Performance may vary – North American model only.
WIRELESS USB RECEIVER:
Processor: 16-bit processing
Dimensions: 2.7" H (68.6mm) x .82" W (20.8mm) x .36" D (9.1mm)
Power: USB Power
SYSTEM REQUIREMENTS:
Internet: Standard broadband connection to download and authenticate software
Hardware: 4 GB of RAM and 10 GB free hard drive space
Platforms: Windows 7 or later , OS X 10.6.0 or later
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.017131 Seconds Memory Usage: 1.909279 Megabytes
