Hiscox LiteFlight PRO-AC II Gypsy Guitar Case Hiscox LiteFlight PRO-AC II Gypsy Guitar Case Hiscox Ultralight, bomb proof Gypsy flight case made in the UK! Arts & Entertainment hiscox-pro-ii-ac-gypsy PRO-II-AC 5.0 1
5 5
Amazing! Very light weight and the most protective case I have ever owned.
399.99 DjangoBooks.com
Home / Guitars / Guitar Cases / Hiscox LiteFlight PRO-AC II Gypsy Guitar Case
Highly protective, light weight (~10 lbs) guitar case sized for Selmer Maccaferri Gypsy guitars with a lower bout up to 16 1/4" and up to 680mm long. Features include composite double molded construction with a 2 mm impact / crush resistant ABS outer shell bonded to an inner moulding of semi-rigid cellular foam to absorb impact energy. The padded interior is lined with silver-grey velour and has an ample accessory box. There is also an aluminum perimeter valence to increase shell rigidity and provide an extra secure attachment substrate for the latches and hinges. In addition to the impact protection, the inner cradle also provides excellent thermal protection. There is also a comfortable handle as well as D-rings for a shoulder strap (not included). Imported from the U.K.
9923 - Hiscox LiteFlight PRO-AC II Gypsy Guitar Case
$399.99 | Out Of Stock | Stock Notification
hiscox
Submitted by: jojabeau on 01/07/2015 09:21:08 AM
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.017466 Seconds Memory Usage: 1.890694 Megabytes
