Kent Armstrong Built-In Single Coil (Handmade) Kent Armstrong Built-In Single Coil (Handmade) Kent Armstrong Classic vintage single coil sound without the hassles of 1950s pickup! Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories > Guitar Accessories > Electric Guitar Pickups kent-armstrong-built-in-single-coil Built-In Single Coil 179.00 DjangoBooks.com
Home / Amplification / Pickups / Kent Armstrong Handmade Pickups / Kent Armstrong Built-In Single Coil (Handmade)
This wonderful floating single coil pickup is an excellent alternative to the classic pickups of the 40's and 50's. Kent Armstrong has succeeded in capturing the vintage character of the old DeArmond, Gibson P-90, and Stimer pickups without sacrificing the reliability, adjustability, and ease of install that you'd expect of a new pickup. This pickup features adjustable pole pieces, which allows one to properly calibrate string balance for any type of steel string (nickel, bronze, or copper.) High quality shielding and potting significantly reduces hum which is a constant problem with the original vintage pickups. Handmade in Grafton Vermont by Kent Armstrong.
Specs:
Magnet ­ Alnico V Bar
Cable ­ Miniature single conductor co-axial.
DC resistance ­ 9K Ohms (coil tap option is switchable 9K or 13.5K Ohms)
Body Measurements ­ 2 11/16" x 1 3/16" x 7/16"
Buy 1-3:
$179.00 Each
Buy 4-99999+:
$143.20 Each
Item Options
Strings Spacing Options for 7 String
If you're ordering a 7 string model please choose the desired string spacing.
Not Applicable
57mm String Spacing
60mm String Spacing
Would you like the coil tapped version?
No
Yes
Which finish would you like?
Black
Chrome
Gold
Would you like the Seven String version?
No
Yes ($10.00)
Software: Kryptronic eCommerce, Copyright 1999-2024 Kryptronic, Inc. Exec Time: 0.0444 Seconds Memory Usage: 4.814514 Megabytes
