Krivo Django Bucker with Adjustable Pole Pieces and Volume Control Krivo Django Bucker with Adjustable Pole Pieces and Volume Control Krivo Great alternative to the Stimer pickup handmade in Portland, Oregon! Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories > Guitar Accessories > Acoustic Guitar Pickups krivo-django-bucker-adjustable-volume Django Bucker 220.00 DjangoBooks.com
Home / Amplification / Pickups / Krivo Pickups / Krivo Django Bucker with Adjustable Pole Pieces and Volume Control
These are the THINNEST ON THE MARKET: 4mm thick
Krivo Pickups for  Django  Gypsy Jazz (Selmer) Style guitar (works on oval or D hole guitars.)
DJANGOBUCKER  humbucking noise free pickup
THIS is the ONLY  Humbucking  Pickup for Gypsy Jazz Guitar. Slimmer in Profile than Both "Stimer"  And "Peche La Mouche" models.
Hand Wound with vintage Formvar Wire, Mogami cable, Neutrik connector, and Real Maple Wood finish.
Excellent alternative to traditional "Stimer pickup".  These pickups are very responsive to EQ so a wide range of tonal colors are at your disposal, from bight and transparent to thick and colored.
Works equally well with a tube amp or Schertler, AER type acoustic amps.
Uses neodymium magnets for Clarity and Brilliance with strong lows.
My innovative "Optimized Microphonics" design Senses acoustic vibrations from soundboard in addition to string vibrations.
(This pickup has great string balance, Specialized for use with  Argentine type strings,  Adjustable poles so you can use ANY strings you like,  adjustment wrench included.)
Mounts with INCLUDED non invasive easily removable putty.  No modification to instrument, mounts in seconds.
fully shielded for noise elimination.
less than 4mm thick, very lightweight.
excellent  transparent Acoustic tone.
Uses regular 1/4" guitar cord, just plug right in!
Krivo Manual PDF
9990 - Krivo Django Bucker with Adjustable Pole Pieces and Volume Control
$220.00 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013048 Seconds Memory Usage: 1.347069 Megabytes
