Phil Jones Bass Bass Engine 17  Phil Jones Bass Bass Engine 17 Phil Jones Pure Sound Very powerful, lightweight unit with amazing tone and projection! Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers phil-jones-bass-engine-be-17 BE-17 429.99 DjangoBooks.com
Home / Amplification / Amplifiers / Phil Jones Bass / Phil Jones Bass Combos / Phil Jones Bass Bass Engine 17
PHIL JONES BASS
Start Your Bass Engines
Give your bass the extra shot of oomph it deserves with the Phil Jones Bass Bass Engine 17! This 70-watt bass combo amp boasts high-fidelity sound from 31Hz to 22kHz, thanks to its Class D amplifier with linear analog preamp and proprietary 7-inch speaker design. The 7-inch woofer finds a superb sonic compliment in the 3-inch high-frequency transducer for reliable sound every time you flip on the switch. Bassists can also take advantage of the latest Qualcomm Bluetooth codec and 3-band EQ built right into the Bass Engine 17.
Equipped with everything you need
With the Bass Engine 17, you’ll uncork 70 watts of RMS power, a singular channel for plugging in your favorite axe, and tons of tonal charm. You can easily contour your sound given the included 3-band EQ with bass, mid, and treble controls. But given the Bass Engine 17’s high fidelity sound, you can use it as an amp for other instruments as well — keyboard, guitars, and even vocals. This combo amp isn’t a one-trick pony! You can further expand the Bass Engine 17 by connecting devices via Bluetooth or connecting drum machines and other stereo sources through the L+R line-in sockets.
Stellar build quality
The Bass Engine 17 features all-digital circuitry that’s more than a match for any bass guitar you can throw its way. We have found that the component quality of the Bass Engine 17 is second to none! This combo amp is easily transported from rehearsal hall to gig at only 14 pounds in weight. Lastly, a steel, kick-proof grille rounds out the charms of this Phil Jones Bass combo amp.
Phil Jones Bass: a saga of superior sound
From his first bass, amp, and speaker cabinet builds in 1968 to the founding of multiple internationally acclaimed sound design ventures, London-born Phil Jones has seen it all when it comes to crafting the finest examples of premiere audio performance. Founded in 2002, Phil Jones Bass takes Phil’s love for the 4-string and his drive for sonic refinement and perfection to new heights with the development of top-shelf amplifiers, cabinets, preamps, and more. Equipped to serve bassists with remarkable tone through proprietary technology, equally noteworthy quality, and versatility, PJB products set the bass bar extremely high. Hear the PJB difference for yourself today!
Phil Jones Bass Bass Engine 17 70-watt Bass Combo Amp Features:
  • Packed with a 7-inch high-efficiency speaker and a 3-inch high-frequency transducer
  • 70 watts RMS Class D power
  • 3-band EQ for tone sculpting with bass, mid, and treble
  • A great bass amp that can also be used with other instruments or vocals
  • Connect drum machines and more via the L+R line-in sockets
  • Aux-input jack and headphone output included
  • High-fidelity from 31Hz–22kHz
  • Built-in Qualcomm V5.1 Bluetooth codec for supremely detailed and full Bluetooth sound
$429.99
Amp Specs
  • Type: Solid State
  • Number of Channels: Single
  • Total Power: 70W
  • Speakers: 1 x 7" PJB Ferrite Speaker, 1 x 3" PJB Tweeter
  • EQ: 3-band EQ
  • Inputs: 1 x 1/4" (instrument), 2 x (L/mono, R Line in), 1 x 1/8" TRS (aux in)
  • Outputs: 1 x 1/4" TRS (line out)
  • Headphones: 1 x 1/4"
  • Bluetooth: Yes
  • Power Source: Standard IEC AC cable
  • Height: 11.4"
  • Width: 11.4"
  • Depth: 9.8"
  • Weight: 14.8 lbs.
  • Manufacturer Part Number: BE-17
BI-12 Bass Instrument Cable
$109.99 $99.99 (Save 9%)
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.014263 Seconds Memory Usage: 1.419167 Megabytes
