Phil Jones BP-800 Amplifier Phil Jones BP-800 Amplifier Phil Jones Bass Small and lightweight just got more powerful with the introduction of Phil Jones Bass’s BP-800 bass amplifier. Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers phil-jones-pure-sound-bp-800 BP-800 889.99 DjangoBooks.com
PHIL JONES BASS
Small and lightweight just got more powerful with the introduction of Phil Jones Bass’s BP-800 bass amplifier. The BP-800 is a high power, high performance no compromise compact amplifier that delivers more bass for the buck at a street price of 9. The BP800 features a Class A pre-amp with the popular PJB 5-Band EQ.
Although it weighs only 5.7 lbs and is 7.5” wide the BP-800 is built with the ruggedness and precision needed to withstand all the rigors of live performance and the road. The appealing blue front panel is a quarter inch thick and CNC machined while the chassis is built from thick aluminum extrusion making it incredibly strong. All control knobs are PJB design solid aluminum billet for a high end look and feel.
The BP-800 will work on any AC voltage from 100- 240 volts AC enabling it to conveniently travel worldwide without having to switch to local AC supply voltages. The Power Output is 450 watts into 8 Ohms, and 800 watts into 4 ohms (maximum load). The dimensions are 7.5” wide x 2.5” high x 12.5 “deep.
Other features include Mute /Passive/Active Switch, Headphone out and auxiliary input jacks, Balanced line out with pre/post EQ and ground lift switches, FX send/return Jacks, Pre Amp out and Power amp input jacks and a High-Current Speakon Out.
$889.99
Specs
Model BP-800
Power Output (RMS) 800w/4Ω, 450w/8Ω
EQ 5-BAND EQ
Input 1 x Input , 1 x mini Sw(Mute/Low/High)
Output Speaker-Out, DI-Out, Line-Out、Headphone-Out
Other AUX-Input, Gigbag
Power 100 - 240V AC
Dimensions 7.5 x 12.5 x 2.5 inch /  190 x 317 x 63 mm (W x D x H)
Weight 5.7 lbs / 2.59 Kg
Phil Jones Bass Cab 47 Cabinet with Cover
The PJB Cab 47 is the answer for a powerful cabinet, at an affordable price.
$549.99
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.018274 Seconds Memory Usage: 1.933601 Megabytes
