Phil Jones Bass M-300 Bass Amplifier Phil Jones Bass M-300 Bass Amplifier Phil Jones Pure Sound Phil Jones PURE SOUND M-300 Bass Amplifier Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers phil-jones-pure-sound-m-300 M300 995.99 DjangoBooks.com
Home / Phil Jones Bass M-300 Bass Amplifier
PHIL JONES BASS
If you have had the good fortune to hear music through good high fidelity equipment, then you know what good sound is. If you haven’t...boy are you going to be surprised.
Powerful, clean, uncolored sound...and flawless reproduction is the goal of high fidelity. Let’s hear bass the way it was intended to be heard on well-engineered records: authoritative, tight, taut, punchy, powerful, present, smooth and throbbing. That is what the M-300 delivers in spades. Hi-fi sound for live bass. 2% silver solder connections; 2.5 mm steel chassis; heavy duty chrome plated corners; recessed allen bolt mounted handle; custom machined metal and anodized aluminum knobs; and much more.
2 ch pre amp 5 band Graphic EQ x2
Limiter x 1
Size: 15.75 x 5.25 x 12.75
Accessories: Power cord, Allen key set
Power Output: 450W RMS
Volts: 110 & 220 AC
6900 - Phil Jones Bass M-300 Bass Amplifier
$1,449.00 $995.99 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.011933 Seconds Memory Usage: 1.182564 Megabytes
