Phil Jones W-8 PA Speaker (PAIR) Phil Jones W-8 PA Speaker (PAIR) Default Manufacturer Phil Jones PURE SOUND W-8 Arts & Entertainment phil-jones-pure-sound-w-8-speaker 6900 995.99 DjangoBooks.com
Home / Phil Jones Pure Sound PA Systems / Phil Jones W-8 PA Speaker (PAIR)
PHIL JONES BASS
The W-8 is a full range wide dispersion (180 ° Horizontal) high power loudspeaker for PA and worship applications. The vented Plywood
enclosure houses a proprietary
Neodymium low and 2 high frequency speakers that make this speaker have incredible power to weight ratio.
The W-8 sounds more like hi-fi speaker than PA but with the ability to play
loud and clear from rich deep bass to silky smooth highs.
The W-8 cabinet features threaded inserts to facilitate easy wall or ceiling mounting.
Type2 x 3.5" drivers, 1 x 8" woofer
Sensitivity92dB/W/M
Impedance6 ohm
Frequency Response50Hz - 20KHz
Power200W
Size15.9 x 9.8 x 11.3 inch
Speakers2 x 3.5" drivers, 1 x 8" woofer
Net Weight17.2 lbs
6900 - Phil Jones W-8 PA Speaker (PAIR)
$1,295.00 $995.99 | Out Of Stock | Stock Notification
Briefcase Amp Cover
Briefcase Amp Cover
$29.99
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.019859 Seconds Memory Usage: 1.383286 Megabytes
