Raezer’s Edge cabinets have gained the highest reputation in
the Jazz and Blues communities for delivering a big focused sound in a
small portable cabinet. Now introducing the Nighthawk – 22 pounds of
pure, clean, undistorted tone in a 14” x 14” x 10” birch construction
bass reflex ported cabinet.
As with our Stealth Extended Range (ER) cabinets, the Nighthawk tonal
range spans from 55 Hz to 16KHz+. We didn’t skimp on the high frequency
driver either. The Nighthawk uses a Pro Sound Eminence coaxial mounted
NSD-2005 driver with titanium diaphragm. Not only does this driver
deliver crystal clear highs, it beautifully reinforces the mid range
frequencies as well.
With the rear mounted L Pad turned to zero, the Nighthawk delivers a rich, smoky jazz tone, much like that of our Twin 8 cabinet. The tonal personality of the Nighthawk changes dramatically as the L Pad is dialed in. From dark and smoky to full range with plenty of punch – its hard to believe it’s all from one cabinet!
In addition, you will smile every time you transport the Nighthawk. With its recessed handle, small size and light weight, it’s a pleasure to take to your gig.
Features
- Power: 250 watts
- Speaker: Eminence Beta 10CX @ 8 Ω
- Dimensions: 14”w x 14”h x 10”d
- Weight: 22lbs
- Frequency range: 55 Hz to 16KHz
