Pickup Cable - 10 ft. (Right Angle RCA Jack) Pickup Cable - 10 ft. (Right Angle RCA Jack) Default Manufacturer Pickup Cable - 10 ft. (Right Angle RCA Jack) Arts & Entertainment right-angle-stimer-cable-rca-10 9992 5.0 2
5 5
High quality cable,a must have if you own a stimmer pickup. The stock cable gets in the way.
5 5
The cable works great. The original cable that came with the pickup died on me within 5 months. This cable is the same size and is L shaped so it doesn't touch your leg. BUY IT-GOOD INVESTMENT!
35.00 DjangoBooks.com
Home / Amplification / Pickups / Stimer Pickups / Pickup Cables / Pickup Cable - 10 ft. (Right Angle RCA Jack)
This custom made, high quality insulated cable is designed specifically for use with a Dupont Stimer, Kleio, and Peche a la Mocuhe pickups. Unlike the standard cable, this one uses a right angle RCA plug which directs the cable towards the tailpiece. This keeps the cable away from the players leg, which has tendency to jostle the cable and knock the pickup loose. By directing the cable away from your leg, you will gain added stability and greatly reduce accidental unmounting of your pickup.
This cable only works with pickups fitted with RCA jacks. Some pickups have mini-plugs and are therefore incompatible with this cable.
Stimer Pickup Cable - 10 ft. (Right Angle RCA Jack)
9992 - Stimer Pickup Cable - 10 ft. (Right Angle RCA Jack)
$35.00 | Out Of Stock | Stock Notification
gat purchase
Pros: high quality
Cons: none
Submitted by: ihscout on 08/17/2012 02:53:43 PM
Works great!
Submitted by: Marcos on 12/10/2011 05:44:02 PM
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.033544 Seconds Memory Usage: 4.891304 Megabytes
