Pickup Cable - 15 ft. (Right Angle RCA Jack) Pickup Cable - 15 ft. (Right Angle RCA Jack) Default Manufacturer Pickup Cable - 15 ft. (Right Angle RCA Jack) Arts & Entertainment right-angle-stimer-cable-rca-15 9993 40.00 DjangoBooks.com
Home / Amplification / Pickups / Stimer Pickups / Pickup Cables / Pickup Cable - 15 ft. (Right Angle RCA Jack)
This custom made, high quality insulated cable is designed specifically for use with a Dupont Stimer, Kleio, and Peche a la Mocuhe pickups. Unlike the standard cable, this one uses a right angle RCA plug which directs the cable towards the tailpiece. This keeps the cable away from the players leg, which has tendency to jostle the cable and knock the pickup loose. By directing the cable away from your leg, you will gain added stability and greatly reduce accidental unmounting of your pickup.
This cable only works with pickups fitted with RCA jacks. Some pickups have mini-plugs and are therefore incompatible with this cable.
Stimer Pickup Cable - 15 ft. (Right Angle RCA Jack)
9993 - Stimer Pickup Cable - 15 ft. (Right Angle RCA Jack)
$40.00 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.019859 Seconds Memory Usage: 1.346596 Megabytes
