Schatten HFN-C Artist Plus 1 Pickup for Classical Guitar (Includes Pre-Amp and 1 Thumbwheel control) Schatten HFN-C Artist Plus 1 Pickup for Classical Guitar (Includes Pre-Amp and 1 Thumbwheel control) Schatten Design Schatten HFN-C Artist Plus 1 Pickup for Classical Guitar (Includes Pre-Amp and 1 Thumbwheel control) Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories > Guitar Accessories > Acoustic Guitar Pickups schatten-hfn-c-artist-plus-1 HFN-C Artist Plus 195.95 DjangoBooks.com
Home / Amplification / Pickups / Schatten Design Pickups and Preamps / Classical Guitar Pickups / Schatten HFN-C Artist Plus 1 Pickup for Classical Guitar (Includes Pre-Amp and 1 Thumbwheel control)
  • Works with All Nylon-string Guitars
  • Active System, Includes Artist II Preamp
  • Can be Remotely Powered
  • Easy to Install
  • Full Two-year Warranty
"The sound of this new guitar pickup is as close to that of a good quality mic as you've ever heard from a guitar pickup......"
The HFN-C models give you a sound that is much more realistic and acoustic than anything that you have ever experienced before. More realism in attack, more realism in overall response, these pickups actually allow your instrument to sound just as good plugged in as it does unplugged.
The only thing missing from the HFN-C in a classical is the 'quack' that everyone has come to expect and accept in classical acoustic pickups. As well, there is nothing artificial about the sound of the HFN-C's and the usual under the saddle sound is replaced with the actual acoustic sound of the instrument.
The HFN-C piezo sensing unit fits inside the instrument and spans the center brace or reinforcement strip. Due its' design, this series of pickups produces sound much closer to that of a good microphone than any under the saddle pickup or bridge replacement pickup that you've ever heard.
Artist II Preamp
The HFN-C Artist pickups include the new Artist II preamp, a high quality dual channel preamp built right into the endpin jack. This pickup can be used with or without an external preamp/eq/mixer, or can be plugged directly into your amp or PA system.
The Artist II preamp is a dual channel preamp with the HFN pickup wired to one channel. The other channel is available for a second pickup, such as a magnetic pickup. Trim pots are provided to control the gain for each channel separately to allow balancing of the signals from two pickups. The signals are then blended into a pre-mixed mono output.
The Artist II preamp can be powered in any of the following ways:
  • Powered from a standard 9 volt battery installed inside the guitar
  • Powered from an external Phantom Power source of up to 48 volts using the Schatten CAB-1 cable (not included)
  • Powered from the Schatten RP-1 18 volt Remote Power unit (not included, requires CAB-1 cable)
Installation
There are no jigs or fixtures to mess around with during installation and there are no changes to the saddle, the saddle slot or to the playability of the guitar. All HFN's come prewired and ready to install.
The HFN-C pickup unit securely sticks in place on the bridge plate of your classical guitar with specially supplied self adhesive foam strips. This mounting is very quick and very secure. The pickup may be removed easily however, at any time should you want to move it to a different instrument.
The HFN-C will fit virtually any classical guitar. The only hole that you need to drill is for the endpin jack or endpin jack preamp. Installation is quick and simple and takes about 15 minutes (if you take your time at it).
Each pickup is hand built and tested in the Schatten workshop to ensure good sound. As well, each pickup is warranted for a period of two years from date of purchase.
Active System
$214.95 $195.95 (Save 9%)
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.012732 Seconds Memory Usage: 1.35907 Megabytes
