Schertler Unico Acoustic Amplifier (Wood) Schertler Unico Acoustic Amplifier (Wood) Schertler The Schertler Unico is a powerful acoustic amplifier with 250W of power, 3 channels, and arguably the clearest, most natural sound of any acoustic amp on the market! Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers schertler-unico-amplifier-wood Unico Wood 4.8 8
5 5
I’ve been playing for over 45 years and have owned any number of quality amplifiers, but was amazed the first time I played my new Schertler Unico. The best word I can use to describe the sound is “presence.” I started by playing my guitar acoustically, then slower increased the volume until I could “hear” the Unico. The effect was startling: the room filled with sound ~ but I could not hear it coming from the Unico ~ it was instead emanating from my GUITAR. It was as if the Unico brought m...
5 5
I ditched my crappy Fishman amp and got this, so much better!
5 5
This is now my favorite jazz amp....way more reliable than the old Polytone I used to use and beats similar Henriksen units in terms of sound quality, features, and volume. Also, looks so nice on stage!
5 5
Love it!!!!!
5 5
I've had this amp for three months now and am just blown away by it's versatility and sound quality. It sounds fantastic with nearly anything I put through it: condenser mic, LR Baggs pickup, and even my Fender Tele sound amazing through it. I recently bought the Schertler DYN-G P48 pickup and that sounds way better than the piezo pickup I had been using on my Taylor flatop. Schertler pickup + amp = acoustic nirvana!
3 5
I really wanted to love this amp. While it is very well built and admittedly sounds amazing, I just couldn't justify the expense as I was still able to get a serviceable sound out of my less expensive Roland AC60 (which sounds a lot harsher but it is OK for playing in bars and such.) While the Unico is probably the best acoustic amp you can get, those on a budget can probably do OK with something cheaper.
5 5
Great amp for bluegrass and swing violin!
5 5
I've tried them all, AER, Fishman, Roland, Henriksen, etc and hands down, no one makes a better acoustic amp than Schertler! I'm a professional session musician and also do about 150 shows a year. I use the Unico for all my live work from nylon string Latin styles to archtop jazz to acoustic flatop and even some Gypsy. Great amp that sounds completely natural and can stand up to the rigors of heavy touring.
1856.00 DjangoBooks.com
Home / Amplification / Amplifiers / Schertler Amplifiers / Schertler Amps / Schertler Unico Acoustic Amplifier (Wood)
A Versatile Acoustic Amplifier with a Cutting Edge Features
The Schertler Unico is a powerful acoustic amplifier with 250W of power, 3 channels, and arguably the clearest, most natural sound of any acoustic amp on the market! This unit features a two way 10" woofer, a 1" dome tweeter, and a Class A preamp which will add warmth and clarity to your sound.
The Unico is Equipped with All the Inputs and Outputs You'll Need
The Schertler Unico has three main channels:  one channel with a 1/4" instrument input and two channels with XLR mic inputs which provide phantom power. The second XLR channel also has another 1/4" input, offering even more options for the player. A fourth channel has a mini stereo input for an MP3 player and a fifth channel has stereo inputs for the external effects loop. An insert plug is also included which can be used with Schertler's nondestructive side-chained volume pedal or any other dynamics processing device. The output section includes a Line Out, adjustable DI, and an AUX out as well as a low cut filter and a mute switch.
Advanced Signal Processing is at Your Fingertips
The Schertler Unico features versatile EQ controls with Low, High, and Mid sweeps as well as parametric EQ for added control. The RESON control notches out feedback prone Low Mids, enabling mics or Schertler DYN pickups to achieve substantially more volume before feedback. The WARM button essentially emulates the tone of an AER amp by boosting Mids and cutting Highs, which smooths out quacky, harsh sounding piezo type pickups. An internal digital reverb with a decay control in also included.
6500 - Schertler Unico Acoustic Amplifier (Wood)
$2,468.00 $1,856.00 | Out Of Stock | Stock Notification
Amp Specs
Weight 14.2 kg (31.30lb)
Dimensions 32.4x32.6x43.8cm
Frequency Response 50 Hz to 20 kHz (+/-3dB)
Speakers 1” dome tweeter, 10” woofer
Construction Plywood
Channels 5 indipendent channels
Inputs Channel 1 Jack 6.3mm unbalanced, Channel 2/3 XLR balanced
Channel 4 Jack 3.5mm stereo, Channel 5 2x Jack 6.3mm unbalanced
Outputs DI, LINE, AUX
Phantom Power 10V on Channel 1, 24V and 10V on Channel 2, 24V on Channel 3
Schertler Unico
I’ve been playing for over 45 years and have owned any number of quality amplifiers, but was amazed the first time I played my new Schertler Unico. The best word I can use to describe the sound is “presence.” I started by playing my guitar acoustically, then slower increased the volume until I could “hear” the Unico. The effect was startling: the room filled with sound ~ but I could not hear it coming from the Unico ~ it was instead emanating from my GUITAR. It was as if the Unico brought my guitar to life. Needless to say, the Unico has remarkably clear acoustics and incredible sound reproduction. Just make sure your guitar sounds good in the first place because that’s what you will hear!
Submitted by: Andrew on 11/05/2024 07:16:30 AM
Great Amp!
Submitted by: jb on 08/02/2018 09:43:55 AM
Unico
Pros: Good looks, great features
Cons: Could use more effects
Submitted by: jazzpicker on 08/01/2018 05:56:09 AM
Wood Schertler Unico
Pros: Great looks and sound
Cons: None
Love it!!!!!
Submitted by: Spencer on 07/10/2018 06:06:45 AM
Unico
Pros: Light weight, Great reverb
Cons: Coukd use one more channel
Submitted by: M. Gonzalez on 06/28/2018 04:18:52 PM
Unico Amp
Pros: Near perfect acoustic tone
Cons: Expensive
Submitted by: Jack M. on 04/08/2018 03:44:53 PM
Unico
Pros: Pure Acoustic Tone
Cons: A little heavy for me
Submitted by: Victoria on 12/13/2017 08:53:19 PM
Schertler Unico
Pros: 250W, three channels, Reson Control
Cons: A flight case would be nice
Submitted by: Sandy on 08/20/2017 04:05:09 AM
SMS Monitor Speaker Stand
Stand for monitor speakers.
$179.00 $129.00 (Save 28%)
Out Of Stock
Schertler S2 Stand
Monitor stand for SCHERTLER amps models JAM 100, JAM 150, David, Unico. Soft rubber rests pads firmly hold amps while adjustable leveling foot compensates for uneven floors.
$102.00
Unico Gig Bag
Gig bag Unico Amp.
$192.40
Outlaw Amp Ramp
$26.00 $19.99 (Save 23%)
Volume Pedal
$101.40
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.327087 Seconds Memory Usage: 1.671341 Megabytes
