UltraSound Dean Markley PRO-250 Acoustic Guitar Combo Amplifier UltraSound Dean Markley PRO-250 Acoustic Guitar Combo Amplifier UltraSound The PRO-250 is a triamped acoustic amplifier delivering 150W RMS through a heavy-duty 10" Eminence speaker, 50W RMS through a special 4" midrange driver, and 50W through its high-efficiency "supertweeter" driver. Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers ultrasound-pro-250 PRO-250 599.00 DjangoBooks.com
Home / UltraSound Dean Markley PRO-250 Acoustic Guitar Combo Amplifier
Full-range tone for acoustic guitar and vocals in a versatile, powerful amp!
The PRO-250 is Ultrasound's next generation acoustic amp—delivering unmatched acoustic tone in a lightweight combo package. The PRO-250 is a triamped acoustic amplifier delivering 150W RMS through a heavy-duty 10" Eminence speaker, 50W RMS through a special 4" midrange driver, and 50W through its high-efficiency "supertweeter" driver. The super-tweeter is controlled by its own independent volume control and uses active crossover technology for precise control of highs and harmonics.
The PRO-250 features two independent channels; each with volume and active EQ along with independent 24-bit digital effects processors producing studio quality reverbs, delays, and chorus effects. Channel 2 provides an XLR input for your mic, making the PRO-250 the perfect solution for the acoustic singer-songwriter. Auxiliary stereo input for playing along with your MP3 or CD player, drum machine, and other devices. 3 balanced XLR outs, 3 line outs, and 2 effects loops provide complete connectivity for the stage and studio. Global ground lift eliminates ground-loop hum.
FEATURES
  • 250W triamped power
  • 10" Eminence driver
  • 4" midrange speaker
  • Unique "supertweeter" with active crossover and dedicated volume control
  • Dual DSP effects processors
  • Mic/instrument channels with independent EQs
  • 3 balanced XLR outs
  • 3 - 1/4" line outs
  • Independent effects loops for each channel
  • Tilt-back design for enhanced projection
  • Stereo input for CD/MP3 player or other devices
Boldly amplify every nuance of your guitar's natural tone and your voice. Order the PRO-250 today!
6600 - UltraSound Dean Markley PRO-250 Acoustic Guitar Combo Amplifier
$999.99 $599.00 | Out Of Stock | Stock Notification
Amp Specs
250 watts of acoustic power
Special tri-amp design for even response over the full audio frequency range
10" high powered full range driver, powered by 150 watts
4" midrange driver, powered by 50 watts
High frequency "supertweeter" with active crossover, powered by 50 watts. The Supertweeter has its own volume control for extended versatility with many different instruments.
3 Line outs
3 Direct outs
2 Effects loops
Global Ground Lift, which lifts the ground from pin 1 of the XLR jacks and the sleeve of the 1/4" jacks to break any ground loops between the PRO and a PA system.
Dual "On-board" digital effects processors. (One for each channel)
Auxiliary "Stereo" input for MP3 or tape player
Heavy duty 16 ga. Steel chassis
Plywood cabinet with heavy duty tolex covering, metal corner protectors, and heavy duty rubber feet
UltraSound DI Plus Preamp
$179.99 $99.00 (Save 45%)
Out Of Stock
UltraSound DI Max Acoustic Guitar Preamp
$269.99 $149.00 (Save 45%)
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013536 Seconds Memory Usage: 1.26384 Megabytes
