Shims under bridge?
Someone recommended I put rosewood shims between the bridge and body - Should it be a particular grade or cut? Does it need to be quarter sawn? Any more info would be helpful.
  • swingnationswingnation ✭✭
    Try thin wood veneer. It comes in a roll at most hardware stores or sheets online. Cut to size with a exacto or razor blade. Works well for me.
  • LufsenLufsen New
    I put clarinet or sax reeds under the bridge, and that works for me.
  • StevearenoSteveareno ✭✭✭
    edited April 2012 Posts: 349
    I used popsicle sticks (wooden ice cream sticks). Someone here posted about them. Apparently they're maple and worked perfectly. The ones I got were slightly wider than the old style (wide enuff to fit the width of my bridge with some trimming. Cheap (about $2.00 for a pack of approx 20). Bought em at the local Rite Aid drug store. Just the right thickness (about 1 mm) and easy to cut to shape (used an X-acto knife). Colored them using a wood touch up maker. You can hardly notice them. Very happy I raised the action. My guitar plays and sounds much better (no buzzing), louder and better tone.
    Swang on,
    Jimmy Rosenberg uses an interesting shim:
    Just shimmed it with some cherry veneer - instantly sweeter :0) - With my replacement dupont bridge with some shims my cheap little Gitane dg-250 is starting to sound nice.
Software: Kryptronic eCommerce, Copyright 1999-2024 Kryptronic, Inc. Exec Time: 0.019606 Seconds Memory Usage: 1.008644 Megabytes
