Which bridge for gitane D-500
Okay, was going to try shimming, but I think I'll just get a Dupont bridge. I'm sure this question has been answered here before, but . . .
Which dupont bridge should I get for my gitane in order to make the action somewhere between 3.5 - 4mm?
  • drollingdrolling New
    Well, you'll get differing opinions on this. I bought all three, and even the shortest (1) had to be filed down quite a bit. 4mms also a bit high for my taste. 3 to 3 1/2 is how mine are set up.
  • just the bassplayerjust the bassplayer Huntington, NYNew
    As Drolling suggested, there are other opinions, simply based on indivual preferences. With my Gitane D-500, I found that the #1 and #2 bridges were just a bit too low. The #2 was very close to what I wanted until I straighted the neck with the truss rod adjustment allen wrench. At that point, it was a tad too low for the tone, punch and volume that I wanted.
    I play with a Wegen Fatone 5 mm pick, and use Argentine light strings, by the way.
    I found that sanding the #3 down quite a bit worked out best for me. You might want to try the #2 as it was the closest without all the fuss. Remember, there may be individual differences in the guitars as well.
    Michael
    I 2nd the #2. I used to have a D-500 (cool guitar) and that is what I ended up with. The #1 was too low but the 2 was great for me.
    Josh
  • ViejoVatoViejoVato New
    Not to beat a dead horse... but in case you are unaware michael Collins builds custom bridges and the price is close to the others ...
    email him and he will tell you how to get the measurements ...
    <!-- e --><a href="mailto:[email protected]">[email protected]</a><!-- e -->
    or c'mon on out for DFSW and get one made at his workshop ..
    www.dfsw.net
    miller
    "I don't know where I'm going but I'm on my way"
    my granny 'Meme' Foster circa 1998 at age 102
    Django Jerry Jam - home grown GJ & Dead Ahead pickin'
    http://www.DjangoJerryJam.com
  • dazdaz New
    Anyone out there know where I can get hold a Dupont bridge in the UK?
    Cheers
    Daz
    Do you not want to order one online?
    Cheers
  • dazdaz New
    I would be happy to order on-line; if someone could let me know the URL I'd be grateful. Apologies if this is common knowledge on the forum, but I'm new here!
    Cheers
    Daz
    Here are sources I know of:
    http://gypsyguitar.de/shop/index.htm
    (Go to menu item "07 Zubehor" and then choose "bridges")
    http://gypsyguitars.com/accessories.php
    I think these next ones are Dell'Arte bridges, not Dupont and note they are made of ebony -- I'd rather have rosewood or "ebonized rosewood):
    http://****/productStore.php?pno=2&prod=6&sp=1
    John
    Note on Ebony bridges:
    For the D-500 I would not order an Ebony bridge. Go with Rosewood (Dupont). You can get them "ebonized" so they are black but they are still rosewood. Your best bet is gypsyguitrs.com I know that Jacques is out of the country right now but will be back soon so you won't be able to place an order until then.
    Josh
  • dazdaz New
    Thanks guys!
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005827 Seconds Memory Usage: 0.999222 Megabytes
