here's where it was asked before: http://www.djangobooks.com/forum/discussion/6501/
I'd just go with the closest to low E height and lower the bridge as needed while fitting to the top.
Check with Caravan if they have bridges made by Dan Hunt in stock.
I got one few years ago and love it, rings so nice when tapped by itself.
Same type of question; for guitars sold here the action is specified as one measurement. I have just assumed that it's the height of the high e string over the 12th fret. Is that correct?
One more thing.. How much is gonna a different bridge height mess up the rest of the guitar setup? Sometime ago I wanted to order a custom bridge for my guitar but I backed off because I was affraid that a lower bridge would cause neck problems..
Nejc:
A much lower bridge may affect your intonation, so you may have to move the bridge slightly closer to the neck, but it can't / won't "mess up" anything. Lower action could lower your volume, too, and if you lower it too much, you could get fret buzz.
GouchFennarioNewALD Originale D, Zentech Proto, ‘50 D28
(5 years later…referring to my scrawled notebook:)
A few years back I bought a Dupont bridge and measured it with a micrometer, with the base sitting on a flat machinist’s stone. The high spot was toward the center of the bridge, and it was super-close to the as-spec’d 19mm. It wasn’t totally flat across the bridge top, it had a built-in taper. That was what I wanted- it gave me a little leeway to finesse the action. I didn’t expect, and probably nobody should expect, a perfect adjustment-free fit with a new bridge (especially on a non-Dupont instrument).
That said, I actually don’t know what the Dupont replacement bridge factory numbers are supposed to measure (hi E? bridge peak?).
