FS: Headway EDB-1 Preamp & AT Pro 70 Mic
jerojero Michiana✭✭✭✭ J.P. Favino, Godefroy Maruejouls
edited May 2018 in Classifieds Posts: 63
Dear gypsy jazz friends,
I'm selling my Headway EDB-1 Preamp, as well as my Pro-70. I'm asking $150.00US for the EDB-1, and $60.00US for the Pro 70. The Pro 70 includes the violin mount -- when used on a guitar's tailpiece, it really helps cut down on feedback. Both come in their original packaging, and are in great condition -- they've only been gigged with a few times.
The EDB-1 is the now discontinued precursor to the EDB-2 (364.99 retail), and much more powerful than the entry-level EDM-1 (219.59 retail -- sorry for the confusing acronyms). For those of you who don't know it, it's a pretty fantastic little preamp and notch filter. It has two inputs (one 1/4 inch, one XLR), allowing you to blend a mic with a pickup.
Here are the details from Headway:
"With the compact Headway EDB-1 (Sheer Acoustic Equaliser Direct Blend) mega multi-purpose external pre-amplifier box you can completely shape your sound with a 5-band interactive EQ, switchable input impedance, and 3-way range switch. The preamp's controls offer acoustic guitar, bass, or violin settings—which cut unwanted low end tones below the useable frequency range of the instrument. This cuts body-handling noise, unwanted resonances, feedback, and violin bowing noise. Feedback and other resonance problems may be further tackled by a very effective, broad-ranging tunable notch filter and a phase reverse control.
The Headway EDB-1 preamp's inputs provide plenty of options for any amplification you use. Whether using a 1/4" jack, balanced stereo 1/4" jack, or XLR jack for a microphone, the EDB-1 has got you covered. Headway EDB-1 inputs include mono jack, stereo jack and XLR, through 2 channels. The inputs enable you to blend in an extra pickup, or microphone. You can plug into them with 1 or 2 standard mono jack leads, a jack lead plus an XLR, or a stereo jack lead. An unbalanced 1/4" jack would be related to the Channel 1 input. A balanced 1/4" jack relates to the stereo input (using channels 1 and 2), for an instrument using an internal mic and pickup, being blended internally. Channel 2 mic is an XLR input allowing you to use a microphone onstage, if your instrument does not have a pickup.
Each channel's input impedance switches allow you to optimize the voicing for any of the major pickup types, while a huge amount of extra levels can be applied via the gain controls and master volume.
Phantom power is also available to jack in and XLR inputs, making the unit friendly for use with quality condenser mics and Instruments wired with no battery inside instrument, but with active pickups needing powering.
The outputs use a balanced XLR out and a line out jack. If an earth loop is heard causing hum, you may kill it by pressing the earth lift switch. The two outputs also allow you to split the signal, such as between an acoustic combo amp for stage monitoring and an out front mixing desk.
The Headway EDB-1 preamp can be mounted on its rubber feet, carried with you on a belt clip.
Powering is via two 9v PP3 ( 6F22 ) batteries, or via plug-in DC Power supply."
PM for further details.
Best,
J
  • jerojero Michiana✭✭✭✭ J.P. Favino, Godefroy Maruejouls
    PS. Will throw in all sorts of goodies (fancy picks, XLR cables) if bought together.
    Prices lowered -- $150.00 for the Headway, $60.00 for the Pro 70.
    messaged
    edited May 2018 Posts: 63
    Back up for sale!
    Still available
    Pro70 sold! Headway preamp still available!
    Headway preamp still for sale. The marvel of this unit is that you can blend two different sources -- for instance, a magnetic pickup and a mic like the Pro70. Makes for a very versatile tool.
    Yeah, I'm surprised nobody's picked this up. Excellent preamp at an even better price. I have LR Baggs Para but for people using dual source setup Headway is perfect solution.
    Sold!
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.005715 Seconds Memory Usage: 1.010307 Megabytes
