SOLD Bigtone style gypsy jazz bridge pickup with end pin 15-18mm height $75 + s/h
constantineconstantine New York✭✭✭✭ Cyril morin
edited May 2021 in Classifieds Posts: 469
Here is a handmade bigtone style pickup with high quality $100 duncan turner sadducer under saddle piezo element. Pickup sounds great and does not require a preamp. The saddle is also a high quality part optimized for electronics from graph tech. The bridge is much lighter than an actual bigtone pickup and as such does not mute the top. Right now the height of the bridge is about 18mm but could come down to 15mm if you sand it down. 5 inches wide. The end pin is included and you just need to re-solder the connection. The feet are already shaped to an gj guitar. There could be a slight variation in your top which may require a bit of sanding and fitting to your top. I can show you how to do it if you are not sure. Mustaches are not included.
Software: Kryptronic eCommerce, Copyright 1999-2023 Kryptronic, Inc. Exec Time: 0.048861 Seconds Memory Usage: 3.450516 Megabytes
