**** of **** makes a good sounding bridge to custom specs, but he got the string spacing wrong and the treble side on top was way too low. Would not recommend unfortunately. Next time I will order from here.
I am located on the NYC side of that large puddle. But, it seems that so far it doesn't matter what side I live on. There appears to be a rather limited pool of custom bridge makers. So, far I have accumulated a reference to an unnamed bridge maker who did a botch job.
If you want someone to not only make you a new bridge but dial it in for your guitar they'll need the guitar in front of them to do the top fitting, string spacing and so on. Rodrigo is in NYC.
Which side of what pond?
I could build a bridge across the pond for you!
Er.. referring to the body of water between NYC and Europe.
I guessed it would have been one of the world's larger 'ponds', but it still doesn't say which side you are on.....
How about Craig Bumgarner? He makes the guitars, including bridges I'm sure.
Try getting in touch with Rodrigo Shopis via FB.
Thanks for both of those. I think you are on the money.
