Record/play LPs on Mac G5?
robertsaundersrobertsaunders Brookline, MA✭✭✭✭ 2007 Gitane DB-255
edited August 2008 in Recording Posts: 244
A friend of mine has some old Django records stored in his basement! He wants to listen them so I invited him to come over and see if I could get my Yamaha turntable to play them through my Mac G5. I want to both listen and record. Is this hard to accomplish? There's a Radio Shack down the street for any hardware I need to adapt the turntable's cables to Mac plugs, but I also need software. I read that Final Vinyl does this type of conversion. Is this good software? Are the connection cables going to be a problem? Advice appreciated. Thanks in advance,
~Rob
  • AdelaarvarenAdelaarvaren Ballard, WA, USANew
    For the software, download Audacity - it is free.
    For the cabling, you'll probably need a preamp or amp. Do you have a hi-fi receiver somewhere that has a "phono" input and a tape out? This would be an easy solution. Otherwise you'll need a preamp to boost the signal. Then the output of the receiver or preamp can go into the line in of your computer, usually with a RCA to 1/8" plug.
    Good luck :)
    Also, for under $100 you can buy a USB turntable, you'd probably get a better recording that way. By the way, with Audacity you probably want to record at 44.1KHz rather than 48KHz. 48 is for DVD audio. Also, 16-bit stereo is all you need for this kind of audio.
  • robertsaundersrobertsaunders Brookline, MA✭✭✭✭ 2007 Gitane DB-255
    Alas, I have no old hi-fi amp lying around...maybe I'll canvas my friends to see if anybody is throwing one out. Otherwise it's spend $ for a pre-amp, no way around it. Audacity is the program I hear recommended the most so I'll go with that.
    Thanks!
    Rob
Software: Kryptronic eCommerce, Copyright 1999-2024 Kryptronic, Inc. Exec Time: 0.019515 Seconds Memory Usage: 1.008797 Megabytes
