Dry vs. Wet Tone
Can anyone weigh in on what construction aspects of a gypsy guitar make it more dry (less booming, ringing, overtones)?
    A stiff top, overall strength but especially light and strong top and bracing. Top stiffness both with and against the grain so it acts as a unit rather than reacting one way north and south and differently (weaker) east and west.
    I only say this cause I read this in luthiers writings, so I can't discount luck, other variables, magic or secrets.
  • asd123321asd123321 ✭✭✭✭
    The bridge is high, the top is arched and the braces are parallel not an x. The small opening can kill the bass.
    A high bridge implies a decent neck angle, yes?
    I wonder what is the range on neck angle. As I recall people have mentioned around 2.5 degrees.
    Thanks for the replies
  • HCQHCQ Northeast NJ✭✭✭
    Construction aspects aside, damping or isolating the tailpiece goes a long way in taming overtones.
    I just did some DIY work on my Dell Arte Pigalle, (Music Link). Its an Asian guitar. There have been a few fixes to cut down on "wet" tones on other threads here. On my guitar, notes that match up to notes on opens string have a sympathetic ring to them. Additionally, these notes are louder because of these overtones.
    The notes that noticeably do this are mostly on the high E string. B at the 7th fret, D at the 10th fret, E at the 12th, G at the 13th and A at the 15th.
    Some folks recommended stuffing cloth, which I did, or putting some cork under the tailpiece.
    Today I took off the tailpiece pulled the red leather off and replaced it with some black felt carefully trimmed to fit the tailpiece profile. I got the felt at an art supply store. its about 2 millimeters thick and fairly stiff. I chose black but its available in about a dozen colors.
    Anyway, this really dried up my guitar without killing overtones completely. The wet notes lost about 80%-90% of their ringing overtones. They also have a much more similar volume as other notes when playing normally. I thank the folks here whose recommendations that led me to the best, easiest and cheap solution to a common problem.
    The black felt looks great too.
    Now, if they made it in Lake Placid Blue or Sea Foam Green...... :wink::wink:
    Best,
    HCQ
Software: Kryptronic eCommerce, Copyright 1999-2024 Kryptronic, Inc. Exec Time: 0.016769 Seconds Memory Usage: 1.008797 Megabytes
