pickup talking to steel or nylon strings
hi
let's say that you have a guitar with a pickup and you have steel strings in your guitar and your pickup 'talks' to your strings well. If you put nylon strings in your guitar is it guaranteed that your pickup will work well with your nylon strings ? Or maybe there are separate pickups for nylon strings and separate pickups for steel strings? Please, write comments
  • WColsherWColsher PhiladelphiaNew
    If you're using a magnetic pickup, no. The nylon strings cannot disturb the pickup's magnetic field to generate a signal.
    If you're using a non-magnetic pickup like a BigTone, the answer is yes, but of course you'll have to make adjustments in your signal chain (e.g. in equalization) to accommodate the new strings.
Software: Kryptronic eCommerce, Copyright 1999-2024 Kryptronic, Inc. Exec Time: 0.023358 Seconds Memory Usage: 1.008797 Megabytes
