2-note per string arpeggio
GuillemltGuillemlt New
edited July 2011 in Gypsy Picking Posts: 5
Hi everyone,
I'm just starting on this gypsy world, wich is great and motivating, but a little confusing (to me) about the picking. Here's what I mean:
I assume that the next picking pattern is correct (Amin arppegio):
------------------------8---12-
---------------------10--------
-------------------9-----------
------------7---10-------------
----------7--------------------
----5---8----------------------
D U D D U D D D D
My doubt appears when, assuming this is correct, you play diminished (or a 7th) arpeggio, it seems, to me, like it's not the same "logic" about changing strings, here's what I mean:
--------------------------------8--
-------------------------7--11-----
----------------------8------------
---------------7--11---------------
--------6--10----------------------
--5--8-----------------------------
D D D D D D D D D D (I believe this is the right one)
D U D U D U D D D D (this one is more like the Amin)
My qüestion is, do you really pick all restrokes when running a diminished or a 7th arpeggio with 2 notes (or 1) per string?
Thanks!!!
    Guillemlt wrote:
    Hi everyone,
    No. When playing a 2-note-per-string arpeggio, you use D-U picking. When playing a 1-note-per-string arpeggio, you use swept rest strokes ascending and rest strokes descending.
    That is correct: you should alternate on the same string. In your first example you do that starting out and so the last note (on the top string) would end the run in an upstroke. Likewise in the second example the second run would be right, except the 2nd note of the B string should be an upstroke.
    Of course if you can hammer out downstrokes like a Thundergod it might not matter too much, but I always run into trouble playing too many downstrokes in a row so I stick to this way going up but I also break with the basic rule going down and allow myself an upstroke and alternate if it is just a single note on a string since this is just faster and smoother that way for me. I think Debarre does that too and others also I see once in a while, but it is very hard to notice on video.
  • GuillemltGuillemlt New
    Hi,
    actually I've been playing the way you say (alternate picking on the same string), but I've been looking to some Stochelo and Fapy videos, and, to me, it looks like they are doing all reststrokes when running 7th arpeggios (2 note per string). I mean they change string always "sweeping", so they have to repeat a reststroke on the 2nd note of every string...
    Ok, I don't know if that is "understandable", I believe I just wrote a mess...
    Thanks for the answers!
    Guillem
  • HemertHemert Prodigy
    Actually Guillem, since you are a member of the Rosenberg Academy you know exactly how Stochelo does it?!
    The A-minor arpeggio in your example is not how Stochelo would pick it! The dim arpeggio is closer but Stochelo would almost never use that particular one, he prefers to play those notes on another combination of strings!
    Well,
    the thing is they don't work on this particular issues (maybe not at my low level in GJ), they focus more on licks than whole arpeggios, but as far as I know, the logic would be the same.
    I started with Gypsy Picking (wich is great opened a huge window to me), but since I've been working with both (Gypsy Picking and Rosenberg Academy), I'm feeling a little confused, and I don't know wich way I should take...I guess both ways work fine depending on other aspects.
    Thanks,
    Guillem
    [quote="Guillemlt"]Well,
    Thanks,
    Guillem[/quote]
    What do you mean? Stochelo's technique is pretty much textbook gypsy picking....
    Regarding the arpeggio you posted here's the way most gypsy pickers would do it at speed:
    --D--U-D--U-D--U-D-D--U--D
    The fingering is a bit unusual though......
    Remember downstroke as much as possible and always use a downstroke on string changes.
    No, Stochelo's picking is not at all what's in the text books! Gonzalo Bergara's picking is actually much closer to what's in the text books.
    It is true we don't focus on arpeggios in isolation but there's no need to; all of Stochelo's solos are filled to brim with arpeggios. If you study the tab for his solo on "Minor Swing", "Hungaria" and "For Sephora" in the academy - in which EVERY note has the picking direction transcribed - you'll learn pretty much all the arpeggios you'll need. Also in the "technique course" Stochelo's explains his picking technique in detail. The trick with all the down strokes is using different kinds of down strokes.
    I feel I shouldn't discuss these things too much because...well that's bad for business :D
    Hey! I wasnt' saying it as a bad thing! Having the way of combining arpeggios in a context is great stuff.
    Yes. You're probably right here :-)
    By the way, thanks for replying that fast.
    Hemert wrote:
    ......I feel I shouldn't discuss these things too much because...well that's bad for business :D
    On the contrary, I think that post was quite a nice advertisement. :D
    I don't want to start a battle but... As far as I know there's only one book about the picking technique for this style and that is Gypsy Picking by Michael Horowitz. The technique guidelines written in that book basically describe Stochelo's (And most other gypsies) core plectrum technique as can be confirmed from watching videos of the man playing. My favorites are Denis Chang's productions Gypsy waltzes and In the style of.
    Of course there are subtleties and details that make up his personal style and give him his unique tone and phrasing but I insist that regarding pick direction, the use of rest strokes and the other basic outlines of the traditional way to use a pick for this style, that book describes Stochelo's picking technique almost perfectly.
    BTW I'm not a member of the Rosenberg Academy yet and will probably become one once the site has had more time to upload courses. I'm just going by what's on the videos and comparing it to Horowitz´ book...they match.
Software: Kryptronic eCommerce, Copyright 1999-2024 Kryptronic, Inc. Exec Time: 0.016725 Seconds Memory Usage: 1.008797 Megabytes
