Construction
001dupont001dupont New
in Welcome Posts: 6
Building my first favino. I was wondering if more than 3 braces , per plans, might be needed for the back as I am using solid woods instead of laminate.
Thanks. Jeff
A man who carries a cat home by the tail learns a lesson he can learn in no other way. Mark Twain
    Hey Jeff.
    Good luck with your project. There is a general code around here for posts like this. If you start your subject line with BYO:, then the more talented maker-types (Bob Holo & Craig Bumgarner as pros, many others as semi-pro/amateurs) will see your post easier and potentially reply. That said, if you search the archives using the search bar on the right side of the page under the categories/who's online section using BYO, you'll probably find some great advice for all parts of the process.
    Hope you share photos of your progress as you go along!
  • 001dupont001dupont New
    Thank You....
    billyshakes
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.007608 / 1.062889]
