Min 6 "position" Arps.
lukejazzlukejazz Natchitoches, Louisiana✭✭✭ Dunn Belleville, Dupont MD50
edited October 2022 in Licks and Patterns Posts: 39
Hello All - For whatever reason I never was always getting confused about min6 inversions so I created a worksheet to help me out. I thought I'd share it in case anyone else might like to have it.
I understand it's not really the traditional "horizontal" approach to the arpeggios but it has helped me out so I thought I'd share. Of course ignore the fingerings and play them as you prefer.
billyshakesJSantaBucoBonesBillDaCostaWilliams
    edited October 2022 Posts: 1,657
    Could be useful for people who want to learn to play "in position", thanks. Incidentally, this is actually one of the easiest arps to play with a traditional "horizontal" approach, because you get 2 notes per string. So, gypsy picking = alternate picking :)
    Works on 2's (Em7b5) and 5's (C7) too!
    lukejazzbillyshakesBucoBonesrudolfochrist
    edited October 2022 Posts: 3,338
    Luke, what software did you use to make those charts? Did you do the same for M6 or M7? Thanks
    Wim, on those vertical arps I tend to add the 4th on the way back down (from high E to low E) to facilitate the 2 note per string thing (like you mention on the horizontal arps) on faster tempos to avoid the double down stroke since I'm speed challenged.
  • lukejazzlukejazz Natchitoches, Louisiana✭✭✭ Dunn Belleville, Dupont MD50
    edited October 2022 Posts: 39
    "Luke, what software did you use to make those charts? Did you do the same for M6 or M7? Thanks"
    Hi Bones,
    It's actually pretty involved. I use a technique I developed to put together a book. Musical examples are done in Finale. Everything else is done in Adobe Products. Diagrams are in Illustrator. I convert the music and diagrams into pdf's and png's with Photoshop, then assemble the whole thing with InDesign.
    I haven't done the same for other chord qualities. I'll see if I can look at doing that. Of course it's a good exercise to do the m6 in one inversion, then in the same inversion change one note to get the next inversion in what I think of as "harmonic evolutions" which is how I usually teach chords.
    So for instance when you get comfortable playing, let's say, min6 in the 1st inversion, then exchange the 6 note for a b7 get a min7. Then dom7 by exchanging the b3 for a natural 3, Maj7 by changing b7 for natural 7 etc. Or just min6 to Maj6 by exchanging the b3 for a natural 3. To my thinking mastering one inversion at a time would be the way to go.
    Also I like to have my students take blank chord grids and draw the diagrams out themselves in order to make it "stick" better. Kind of like transcribing. It's always better to do it yourself. I'll attach some blank grids for your convenience.
    Have fun!
    Luke
    DoubleWhiskyBucoBones
    Thanks Luke, I'll print out the grid and do it old skool with a pencil.
    lukejazz
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.020819 / 3.886246]
