Guitars with modern c shape necks
EmilBirkEmilBirk New Gitane DG-300
in International Posts: 26
Hi all,
does anyone know of a GJ guitar with a modern c shape neck. I’ve currently got a gitan dg330 however I find the neck is too wide for me and causes wrist pain every so often.
Ideally, I would like to save up for a luthier(obviously something reasonably priced still) built instrument but any suggestions would be great!
    My Shelley Park has a modern C shape neck. The neck is still a bit wider so it doesn't feel exactly like my steel string Martin acoustic, but it's no problem switching back and forth.
  • EmilBirkEmilBirk New Gitane DG-300
    Thank you I’ll check them out, I never really had any wrist pain playing guitar before I got this guitar. I will say though I don’t stretch before or after practice sessions and most of the time I do around 4 hours a day. My other guitar is a vox bobcat v90 which has a very thin neck and is very easy to play.
    I will toss Cyril Gaffiero in this pool as well. His Modele Originale has a neck that is very close to what I consider an electric guitar feel.
    If you work with a luthier, they can help you get what you want. Good luck!
  • richter4208richter4208 ✭✭✭
    As Michael once told me (and I would have saved some hassle if I would have listened), just get a Dupont
    Jangle_JamieMichaelHorowitzrudolfochrist
    Interesting I’ll check out his prices and so on, thank you
  • riccardomordegliariccardomordeglia New mordeglia
    Hi, I'm writing as a luthier, sorry for my English but I'm writing with the translator. The problem of wrist pain is not so much due to the shape of the neck but to the width-to-thickness ratio. We are talking about ergonomics understood as the relationship between the signature and size of an object and the human body. The neck of an acoustic or electric guitar is normally 44 or 43 mm wide, that of a gypsy guitar ranges from 45 to 48 mm depending on the model. Furthermore, the size of the attachment to the handle should be 11mm greater. The size of the long scale Selmer was 46-57mm between nut and fourteenth fret. A wider neck gauge aids gypsy technique by allowing more space between the strings for pick strike and thicker pick gauges. Many manufacturers keep the size of 57mm at 14 reducing that at the nut and making an acoustic guitar thickness . this causes a greater width in the central part of the neck not proportional to the thickness. classical guitars have a greater width, of 50-52mm at the nut and a thin thickness but the classical technique wants the guitar resting on the left leg and the foot raised, this places the arm and wrist in another position that avoids pain.
    So the solutions are:
    1-Choose a thicker (22mm thick at the nut or even more) or properly proportioned neck
    2-Choose a narrower neck, but this could compromise the gypsy technique for the right hand by having less space between the strings
    3-Change technique and play in classical style but this means having to reset the technique and not being able to use the thumb for the bass
    This in principle, then everyone has different hands and different tendons, different flexibility and different levers, everyone has their own individuality.
    One last thing, and I say this from my old sporting experience, stretching exercises can also be counterproductive, better not to overdo it. Better warm-up exercises and relaxation exercises before playing
    BucoEmilBirkGouchrudolfochristDoubleWhiskyJangle_Jamie
  • DeuxDoigts_TonnerreDeuxDoigts_Tonnerre Lawrenceville GA USANew Stringphonic #503 Basic, Altamira M30D, Eastman AR810CE, Giannini Craviola
    I would say get an Altamira, an Eastman, or a Stringphonic if you are starting out. These guitars I believe all have a very standard neck profile and are widely available and affordable. They are wonderful guitars for learning the gypsy technique. Your hand will get used to the shape of the gypsy neck if you are striving for the gypsy technique.
    With Gitane / Cigano / etc., neck profiles tend to vary greatly. I had a Gitane 250M that had a thin neck like a Fender Stratocaster. It would start to hurt my hand after playing rhythm on only 2 songs. Also had a Cigano and the neck felt like a flat-top neck. Also had a Gitane 500D and the neck felt extra-wide.
    I have had an Altamira M30D for 10 years and a Stringphonic Basic 503 for over a year. I am so used to playing on these necks that most other "normal" guitar necks now feel foreign to my hand. I have a flat-top, several semi-hollows and several archtops that I hardly play anymore.
    I was looking at the stringphonics, the only worry I have with them is the shipping internationally, from what I know they don’t have a retailer in the UK. I suppose though that if something did happen during transit they would replace the guitar
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006119 / 1.062889]
