Plane of the pick
drspringdrspring New
edited September 2006 in Gypsy Picking Posts: 4
Does a down stroke begin above the plane of the strings? Page 17 I think it says "two strings above the string." Do you return to this "above the string" on all strokes but sweep strokes?
I have taught a kind of rest stroke for many years (before electric light) where I tell students to relax the pick qand push through the strings of an inside chord, and then tighten up against a string not in the chord to prevent sounding it. Is this the opposite of Michael Horowitz' Play-Relax?
Never knew I could enjoy being confused.
Dr. Spring
Play it wrong once, its a mistake, but play it wrong TWICE....
    Yes...you play into the guitar.
    Yes....when you play at faster tempos the motion can get a bit smaller.
    Not sure what you mean...
    Good luck!
    -Michael
  • drspringdrspring New
    You asked about my rest stroke (and I can't figure out how to use the quote feature)
    Lets play a D7 in third position (D,F#, C,D). We don't want the 9, so we play from the fifth string through the second string, and then create tension in the pick agaqinst the high e so the pick stops against it
    Dr. Spring
    Just highlight what you want to quote and hit the quote button.
    You should stop on every string, sometimes very shortly. But you're always stopping for a nano second. Yes, then you end by resting on the high E string. But it shouldn't be tense.
    Thanks- I have actually read what you wrote, and it is NOT unclear-but I have to find a whole new head, let alone a pair of hands, to comprehend.
    Dr. Spring
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005893 / 1.052795]
