playing loud in jam sessions
13
    Yes you end up picking not with the tip of the pick but off to the side. Not everyone does but it's very common. You can see how the rest of this Killy pick is all surface checked and oxidized but where I pick is smooth and polished.
    The pick pushes the string somewhat towards the top. A bit like pulling a string bow but the opposite. Instead of pulling on the string, you're pushing down and into the top and then releasing. When you release, it bounces back with the snap. That's where a lot of projection comes from. That's what Joscho does so well.
    Jangle_Jamie
    Hi Jamie, I was in Inverness the week before the jam - bad timing on my part. I absolutely get your point, the Glasgow session can be the same but with added issue of really crap acoustics. This isn't helped by the lack of space which means that participants act like a sound blanket and suck all the sound up. I end up trying to squeeze as much volume as I can which is detrimental to what I end up playing. My usual guitar is a JWC d hole which has quite a loud outputs and I added a soundport which helps me hear it better. Even then I think the sound dissappears into a black hole. Having said that I'd add that practically all the gypsy guitars I've played and heard seem to project more in front of the guitar leading us to believe that the sound quiet to the player. This is borne out by the number of players who, when someone else plays their guitar, say wow that sounds so much better. I try to just trust that the guitar is loud enough, despite what I can actually hear. I must try and get to the Inverness session soon, when is the next one scheduled?
    Jangle_Jamie
    Next session will probably be July 20th at McGregors Bar. Tune of the month is... Lulu Swing!
    Hope to see you there. Looking forward to trying out these theories and reining in the volume a little!!
    edited June 2025 Posts: 635
  • lorenzoplorenzop Madison Wi TucsonNew Risto Ivanovich
    Am I correct in thinking that Joshco's pick is angled down - - AND - - tipped so that face of pick is sorta' facing his left shoulder?
    This video of Joscho's right hand is about as good as you can find:
    BucoBillDaCostaWilliamsvoutoreenieJangle_Jamiebillyshakes
  • Baro_BrombergerBaro_Bromberger Poznan, PolandNew JWC Favino replica
    Had the same problem, raised my action and changed my pick from a 3mm to a 5mm, made a huge difference. It also improved my tone
    BucoDoubleWhiskylittlemarkJangle_Jamie
    edited June 2025 Posts: 950
    One does not have to have high action to be loud and have good tone. Just played with Charlie Roman in a number of jams and he was plenty loud. We exchanged Bumgarner Corazon's and mentioned his action was lower than mine which surprised me and I'd put mine around 2.8 at most. Height can work both ways depending on one's technique.
    Jangle_JamieBucorudolfochrist
  • edited June 2025 Posts: 355
    I forgot about that one! Perfect glimpse of Joscho's picking angle
    What time does the session run ? I can't make the July one but possibly the August one.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006169 / 1.052925]
