5.0mm picks -- Wegen Fatone, Trimus 500?
245
    Do report back @voutoreenie. I would buy it off you if you don't like it. I'd like to try it too
    voutoreenie
    Littlemark, are your EML picks sort of squarish at the tip, with one side of the tip a little longer? I have trouble using that sort of pick, at least for leads.
    Will do - if I feel inspired I might even record a vid.
  • edited July 10 Posts: 488
    Double post
    Two wegens and the EMLs
    Funny, I have the same. Can you play leads with that shape of tip? Also, the casein one squeaks and "scratches."
    Yeah I play leads with it. It's my main pick.
    Who made your picks. My PEEK pick looks smoother.
    I don't hear any noise fun the casein.
    EML -- Eric Lopez. The roughed-up texture on the PEEK pick is not on the tip, which is smooth. It's just for more grip.
    littlemark
    Looks like you haven't used the casein one much. Mine is all textured from finger oils.
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.0059 Seconds Memory Usage: 1.010307 Megabytes
