Minor Swing Intro
gjazzgjazz Atlanta, Ga. USANew
edited March 2005 in Pearl Django Play-Along Vol.1 Posts: 9
Ok Greg, what gives on the Intro lead in. No way I can stretch my fingers between a 12 and a 7 notes at the same time in the first bar.
That has to be a typo, I hope. ;)
Thanks for the great book!
    Those aren't supposed to be played by one person...if you look at the standard notation one line has the stems up and the other has stems down which indicates that there are two separate parts. So pick one and have someone else play the other.
    Good luck!
    -Michael
  • gjazzgjazz Atlanta, Ga. USANew
    OK, I never knew that.
    I'll look closer next time.javascript:emoticon(':shock:')
    Shocked
  • gregrubygregruby Moderator
    The top line in the melody, the bottom the harmony. When the stems go in opposite directions, that implies two instruments. For P.D. it is the violin on the melody and the guitar on the harmony, but playing single notes.
    IF you were to play both parts on the guitar, I would suggest experimenting with the lower harmony and finding a place it lays out a little easier.
    Thanks,
    Greg
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.020481 / 3.348289]
