A few beginner questions
djadamdjadam Boulder, CONew
edited February 2007 in Gypsy Picking Posts: 249
Would it be accurate to say that in rest stroke picking, the movement is initiated by the wrist and driven by gravity?
Do you generally hold the pick the same way for playing rhythm as you do with the rest stroke picking? If so, then I'm also playing rhythm "wrong". Am I going to impede my ability to learn rest stroke by continuing to play rhythm while holding the pick "wrong"?
5 months, 30 days to go...
    Exactly...use as much as gravity as you can.
    The grip is the same...however, if you're switching back between rhythm and lead, it's usually better to turn the pick inward and use the side of it for rhythm. Gives you less resistance and a nice "swoosh" to your playing. This will all be explained in the forthcoming Rhythm book.
    Funny..everyone used to say the first 30 years was the hardest! I guess we've got it down to the first 6 months...
    Good luck!
    -Michael
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006756 / 1.062889]
