Cadences et Solos - translation?
ElliotElliot Madison, WisconsinNew
edited June 2007 in Gypsy Jazz 101 Posts: 551
Does 'cadences et solos' mean endings and solos, or rhythm and solos?
Or something else?
Thanks,
Elliot
    "cadences" means a regular succession of sounds (with an emphasis on regular or consistent).
    So "rhythm and solos" is close: I do not know in what context you found this but they are probably alluding to rhythmic variations in solos.
    Looking a bit further, I found the following musical definitions of the term "cadence":
    - Chord progression that follows certain harmonic rules and that ends a phrase
    - Suite of brilliant phrases played in solo in a concerto or a sonata
    I guess 'brilliant phrases' fits. I guess I forgot to mention it was in French, out of the Givone book.
    Thanks!
    Edited note:
    I recently did some more research on Cadence since it seems to mean the same in English as it does in French, and found that whether it is referred to as a phrase or chord, it's significance is that it suggests conclusion. There are actually a few types as pertaining to chords:
    Perfect: resolves from the V to the I
    Imperfect: goes from I II IV or VI to the V
    Plagal: resolves from IV to I
    Interrupted:resolves from V to other than the I
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.020676 / 3.910759]
