holding a pick
nymnym New
edited March 2005 in Gypsy Picking Posts: 30
Hi!
I Have one more question. I've tried to hold pick exactly as described in the book but Í have found it easier to play if I place the pick so it rests at the first joint of the index finger (first from the tip of the finger). Fingers are then curled quite a lot - so that knucles of the first joint are gently brushin the strings when playing on lower strings. Am I doing somekind of mistake?
    That sounds correct....that's not any different then in the book. Your fingers should be grazing the strings.
    Good Luck!
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006756 / 1.062889]
