Trick for rotating picks.
edited November 2007 in Gypsy Picking Posts: 1,379
Hi,
I just picked up a little trick at the manoucheries forum.
If you're having trouble with your pick rotating while you play or just want to improve it's grip, try this:
Cut two small circles from a fine grain sandpaper (300 grit for example) and glue them to each side of the pick.
Simple as that. Cool uh?
Another one of my own is to do the same but with those glow-in-the-dark stickers. That way if your pick decides to fly out of your hand on the gig, you can find it easier...at least when it happens on a dark bar. :D
Cheers!
  • robrob hollandNew
    its a good tip
    but its easy er to take a pick that's have really good grip
    u know i.am the maker or the gipsy picks
    i don't now if i can put my site here?
    but if u give me a message i will answer all ok?
    handmade gipsy picks , whe playing self proffesional, whe no how a pick must be
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006756 / 1.062889]
