shims
13»
    I have never seen a Collins bridge. I know that the Dupont bridges make a huge difference in tone. So I would think that the Collins bridges do as well. Any good bridge should. The Gintane come with some 2x4 bridge that kills the tone. When you get a good bridge on there the instrument does sound better.
    At this point I don't have any images on fitting a bridge. However I'm sure I'll be doing another in the near future. When I do I'll make sure and take photos and post instruction on my site. Maybe I'll just do a mock install and take photos.... Hmmm I'll have to see if that will work. I'll make sure and let you know if I do that.
    Cheers
  • aa New York City✭✭✭✭
    any directions are much appreciated.
    your directions for fitting the case were great.
    thanks,
    a
    Www.alexsimonmusic.com
    Fitting a bridge blank
    Before you order a new bridge: measure your action height at the bridge. If you like where it is then order a bridge that will keep it the same. If you want to change it then make your order accordingly.
    1. Take the string off of the guitar
    2. Take the old bridge off of the guitar
    3. See if the new bridge will slide in between the "mustache" pieces
    If it does then go to "notching for strings" if not then go to fitting
    Fitting:
    What you will need: A good file, A block of flat wood, Sand paper (not less then 300 grit)
    The fit should be close on the new bridge so make sure to work slow so you don't take too much wood off of the new bridge. Use your file to take off small amounts of wood. Make sure not to just take from one end. You don't want to make the bridge off center. Keep checking the bridge to the guitar after a few stokes of the file. You don't want the bridge to be tight but you don't want big gaps. It should just slide in. When you get close you might want to use your sand paper and block to work the corners just a bit so they are not too sharp.
    Notching for Strings
    ** READ THIS ** There are 2 sides to a bridge. The bass side and the treble side. The bass side is taller or higher then the other. Before you start going to town make sure you have the correct sides in mind
    Note: the best way to do this is it buy bridge/nut files. But you don't have to have them for a bridge. You just have to work slow with what you have. Keep in mind this step can make your action different and or make the bridge not usable. So WORK SLOW
    What you will need: Small file (a tri angle needle file works well) last choice is an exacto knife. A supper sharp pencil (a mechanical one works well or you can take sand paper and thin a normal one)
    1. Using your old bridge put new string on the guitar. Don't tune the string. Keep them lose with just enough tension to keep them straight.
    3. Put the new bridge on
    4. Make light makers with pencil on each side of each string. Don't move the string with when you do this. The strings should be just tight enough to keep them straight.
    5. Take new bridge off
    6. You will be able to see the marks you made. Now you have 2 marks for each string. Like this || in the center of those marks is where the string lives.
    7. If you are lucky and have the good nut files then you have it made from here on out as long as you don't get too file happy and go too deep
    *Needle File: Place the edge of the file in the center of one set of the marks. GO SLOW and start to make a notch. Do this for each string. Don't worry about making the notches deeper for the big strings at this point
    *Exacto Knife: (this is harder) GO SLOW and make a small V for the string to rest in with the bottom of that V at the center of the marks. Do this for each string. Don't worry about making the notches deeper for the big strings at this point.
    8. Put the new bridge on. Make sure you have the bass side on the base side. The higher part of the bridge goes under the low E string.
    9. You want your notches to be half as seep as the string is round. In other words you only want to sink half of the string into the bridge with your notches. This is not easy on the small strings but just do your best to get them close. This is easier if you WORK SLOW
    10. After you have the notches perfect and the bridge is in Tune it up and start ripping. If the action is too high DO NOT TAKE wood out from the part of the bridge that is resting on the top of the guitar.
    Lowering your action:
    1. Loosen your strings and take the bridge off
    2. Take your larger file and start taking of wood from the TOP of the bridge. The Top is where the string sit....The Thin part. Only take a very small amount of at a time. Do I need to tell you to work slow again? Remember .5mm can make a huge difference when it comes to action.
    3. Use your small file to re notch for the strings.
    Keep doing this until you get the action the way you like it. If you want to measure your action do it at the 12th fret with a ruler from the top of the fret to the bottom of the low E string. It should be any where around 2.5mm to 4mm depending on what you like and how you play
    If you have questions feel free to PM me
    Cheers
  • langleydjangolangleydjango Langley, WA USA✭✭✭✭
    Cheers
    Hey Josh as long as you're on a roll how about explaining the theory of relativity for me? :D
    e=mc2
    there you go!
    That's funny. I always thought e=f flat
    A.E.
    murrayatuptowngaller
    ahhh you wise guy you....
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.008131 Seconds Memory Usage: 1.045959 Megabytes
