Who 'Worked Out' The Chords?
13
  • spatzospatzo Virtuoso
    Anyway the 49' recordings are really great for the marvelous sound Django has, the new way he improvises, the way he backs Grappelli solos then letting the trio piano, doublebass and drums alone. I also like the famous shout when the italian pianist imitate Fats Waller at the end of a long solo on "I Saw Stars".
    The story tells they recorded the tunes with a lot of Chianti in a very peculiar atmosphere. I wonder on how many days they made those 70 recordings and also I wonder if it was recorded at 9.30 in the morning after a long night...
    Livorness did a great job with those records that were recently transcribed by the italian writer/periodist/guitarist Fabio Lossani
    http://www.spartiti.biz/metodi/descri_m ... Ref=128652
    spatzo wrote:
    We also have to mention and remember that Django was also the first to compose modal tunes in Jazz History demonstrating that he perfectly mastered tonal harmony and was ready to go further.
    We will have to wait for more than 20 years before the birth of modal Jazz in the states.
    Although I've never set out to prove it, I have always thought this to be true. Django's Anouman, while not a purely modal tune, predates the Mile Davis/Gil Evans Blue in Green by almost a decade. The harmonies are eerily similar.....
    Let us consider now who worked out the chords on the swing rendition of the Dm Bach Double Violin Concerto? South, Grappelli or Django? (it was pretty hard to find the charts for Bach tunes) :shock: Did our "learning" Django worked it out from some Eddie Lang/Joe Venutti unknown record?
    It would interesting to know how they approached that. Although I find Baroque type music is often the easiest to harmonize as the chords are so strongly suggested by the melody. Django probably would have had no problem picking it up by ear.
    I think he was just messing about on some of the tracks from those Rome sessions. But listen to "Blue Skies" and he does seem to forget what chords he is soloing over in the middle eight.
    Just listened to that...it is interesting what he's doing on that solo. I really like that one actually...I see what you're saying about the bridge. Although I think that's some intentional dissonance there which is reinforced with a strong melodic line and phrasing. For me, it's that sort of device that separates the men from the boys. But I guess it depends on your sensibilities and tolerance for "outside" playing.
    Much as I love his playing, I don't think he was infallable but he was as close to it as any musician has ever been; certainly any creative musician.
    True....probably helped that he didn't seem to have substance abuse problems that plagued so many other great jazz musicians.
  • kimmokimmo Helsinki, Finland✭✭✭✭
    Even long before Anouman Django had long modal passages in his tunes. The A-section in Lentement mademoiselle hardly contains any harmonic movement. And then there are tunes like Rhythme Futur and Diminushing Blackness with static augmented athmosphere.
    I find it almost the opposite. Bach's music was based on polyphonic voice-leading rather than melody-accompanied-by-chords. Functional chordal harmony was just about to be developed in his time, but J.S. Bach was one of the last (maybe THE last) great composer who 'till the end of his life still stuck with strict polyphony, where, if you put chords in it, the chords change in every beat - not really usable for jazz accompaniment. Bach's music has been inspiring jazz musicians a lot and some of his music has been played by jazz groups, but I think that's because the strong bass line (again, polyphonic voice-leading) lets you adapt a simpler chord sequence in some of his work.
    What Django does in Bach's violin concerto is in a league of it's own of all jazzified Bach-renditions I've ever heard, it's simply brilliant. I believe Django and Stephane worked out the accompaniment together.
    On my side I was refering to a pure modal composition with "Appel Indirect" ...
    I agree with kimmo when he says that Django's accompaniment on Bach is brilliant (génial in french). Here there is nothing to copy as you have to decide what lines/modulations etc... you will underline in your chords. For me it is clearly a marvel!
    On Grappelli's role in working out/arranging tunes I think the fact he was able to read music and to play piano indicates he should often have had a important role in deciding what to do. For example we have to remind that many tunes were ordered by the record companies, I mean the Quintet had a list of tunes they must record. In those times the scores were available for almost each new tune but of course Django couldn't read the score so I guess Grappelli played the melody and Django worked out the chords immediately while Grappelli played. Just after that I think Django had also a great capacity to catch and transform and, in a way, to crystalize the melodies he just had listen to. The transformation he did in the melody of "In the Still of The Night" is an excellent example of this capacity. He just takes the most important phrase in the melody and he rebuilds it by developping it just as if he considered that Porter (again...) should have done it this way.
    I've heard the "Blue Skies" (Irving Berlin) tune and it seems that first Grappelli "stoled" the first chorus usually reserved to Django after the usual violon theme exposition. Anyway after Grappelli's solo and piano solo Django plays two "A" and then he starts playing the B section giving the impression he missed the bridge (just as he was going to play a third A instead of "B"). In fact I think that he minorizes the bridge playing a VI to I substitution (Fm instead of Ab). That possibility is quite confirmed when he does his second solo as he does exactly the same substitution.
    It seems that all the improvisers insist on quite playing 4 times "A" instead of marking the difference enhancing the major character of the bridge. Only the piano by quoting the melody marks such difference.
    The trading fours that ends the tune indicates that Grappelli didn't stoled the chorus to Django but that it was already planned and structured as follows:
    - Melody violin
    - solo violin
    - solo piano
    - solo guitar
    - trading fours violin + guitar
    I see what your saying, but at first listening Django seems to be following the chords suggested by the melody. For example, look at what he plays on the first few measures. I'd say those are the most obvious chord choices for that melody as they are so clearly suggested by Bach. Not that it's easy, especially for someone with no formal training, but I do believe he would have clearly heard the changes suggested by Bach.
    Yes, that is also a good example of Django's modal innovations. Rhythm Futur too (as Kimmo suggested).
  • thripthrip London, UKProdigy
    In fact "Appel Direct" is exactly the same as "So What", except Miles converted it to minor :D
    i heard that django learned from tabs he downloaded off the net
