Left-hand technique for A9b13 chord in "Improvisation #
Bill McNeillBill McNeill Seattle, Washington, USANew
edited February 2006 in Unaccompanied Django Posts: 70
What's the best way to achieve the suggested fingering of the A9b13 chord in measures 74, 76, and 96 of "Improvisation #2"? I keep switching back and forth between two techniques:
1) Holding a bar on the 5th fret across the four highest strings with my 1st finger, picking up the B on the 7th fret with my 3rd finger, and picking up the C# and F on the sixth fret with my 2nd finger using a one finger double stop.
2) The same as (1), except I use the 2nd finger to make a bar over the three highest strings on the sixth fret.
In general if I see a chord in "Unaccompanied Django" that can be played with a double stop I use one, both to practice the technique and because I can usually see why one works in context. In this particular context, however, it's not clear to me if the double-stop has an advantage, so I'm wondering if people have opinions as to whether there's a "right" way to hit this chord.
    i'd use a conventional bar technique in that context. There are certain situations when a double stop is necessary, but that isn't one of them.
    good luck!
  • Bill McNeillBill McNeill Seattle, Washington, USANew
    Another question about this chord from: where is your thumb when you play it? I find that this particular stretch forces me to leave my thumb on the back of the neck. This is a problem because it breaks the whole thumb-hanging-over-the-low-E-string hand position that I otherwise try to maintain. For example, I find measures 11-12 of "Parfum" difficult because I'm throwing my thumb all over the place when I move between the CM6 and CM and the intervening G9b13.
    It's in the classical position...the thumb is in the middle of the neck.
    You should also play that whole passage in the classical position.
    Good luck!
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.033914 / 1.186775]
