Stimer amp specs
I can't find any spec info on the Stimer reissue amp. Does anyone know what speaker they used and also the tubes? I'm wondering how exact it is to the original because many odd tubes are no longer produced. It looks like EL84s and 12ax7s, but I'd like to know for sure.
    See specs below:
    Puissance : 12w
    Lampe de préamp. : 1 x 6AV6
    ............................. 1 x 12AU7
    Lampe de puissance : 2 x EL84
    Redressement : 2 x 6X4
    .................. ou 2 x EZ90
    Sortie : 8 ohm
    Contrôles : Gain, Tone
    Modèles : Combo
    Housse : Inclus
    Options : Tolex
    Poids : 9,7 Kg
    Dimensions : Hauteur : 44,5 cm
    ...................Largeur : 38 cm
    ...................Profondeur : 18 cm
    Quantité H.P. : 1 X 12" - 8 ohm
  • guit_boxguit_box New
    Any idea what brand speaker is used as well as if it has an alnico, neo, ceramic magnet? It looks too small to be a ceramic magnet, but it doesn't quite look like the alnicos I've seen. The original would have had an alnico magnet.
    I don't know about the original speaker, but I bet it would have been a "field-coil" with a transformer mounted on the frame. They don't make those anymore, to my knowledge.
    6AV6 preamp tube? Wow. Stock up on those, you can't find them on every street corner, that's for sure.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.006303 / 1.060219]
