"Real" pilage
GregLewisGregLewis Chicago, IL (Oak Park)New
Could someone explain what is meant by the term " a real pilage"?
    It is the sharp bend in the top as found on the original Sel/Macs and other guitars of the period.
    Also common on bowl back mandolins. This was usually made by bending the wood over a hot iron or rod.
    Most modern guitars use a dome or curve in the top. Some higher end models from a few makers such as Dupont will use the "pilage" (sic)......
    Rodrigo Shopis uses a real pliage in his guitars as well.
  • GregLewisGregLewis Chicago, IL (Oak Park)New
    So if I understand, the top is either joined together and then bent over a hot iron to form the pilage, or the top pieces are bent to match and then joined. In any event, the top is not bent over curved braces but the braces are carved to fit the curve ("pilage") of the top. Right?
    Which method is most commonly used?
    The bend (pliage) goes across the guitar parallel with the bridge.
  • fraterfrater Prodigy
    Really? I just can't tell that from the pics in his homepage... probably not a very pronounced pliage then.
    I have never played one of Rodrigo's Selmer copies, oddly enough, just the Favino ones (Which are bloody awesome!). But he is very emphatic that he does a real pliage on his "Selmers".
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.019866 Seconds Memory Usage: 3.654877 Megabytes
